a4 c6
Old Aug 20, 2005 | 04:26 PM
miac6's Avatar
miac6
Default a4 c6
I have a new c6 auto with z51 package, how fast do you guys think i can make my a4 Go? Can i really make a4 go as fast or do i need an m6 ? what do you guys recommend. thanks Mike
Old Aug 20, 2005 | 05:02 PM
Pio's Avatar
Pio
If you want to go faster, check these mods out. The following are ballpark numbers, look around the advertisers sites for more details.
CAI (cold air intake) - around $300 for 10 -15 rwhp (although some swear that theres no increas others have "dyno proof")
LT Headers - around $1000 a bit more for the whole system with hi-flo cats for about 20 rwhp to 25 rwhp (not including installation)
Cat back system - around $1000 for about 5 rwhp (again, this has been debated on several threads wether or not those gains are valid)
Dyno Tuning - around $500 - 10-15 rwhp
Cam- +/- 500 (but whats truly expensive is the install and that varies) anywhere from 15 to 40 rwhp depending on the heads used and if you care about emmsions or not.
Heads- +/- $1000 same as above
Then theres gears, stroker engines, Nitrous and forced induction.
If you want to drop your et about 5/10's go for a set of 3.90 gears, CAI a cat back and tuning. For more than that you might need to get into heads and cam.
Right now stop light to stop light I would pick your car to win over a 6 speed 95% of the time, specially with the Z51's 3.15 rear end ratio.
Old Aug 20, 2005 | 05:36 PM
miac6's Avatar
miac6
thanks for all the great information i truly appreciate this
Old Aug 20, 2005 | 08:57 PM
shopdog's Avatar
shopdog
All of that is really fine, but if he wants to win drag races with his automatic, one of the first things he should add is a high stall torque converter. That'll let him holeshot most manual drivers.
Old Aug 20, 2005 | 09:57 PM
Pio's Avatar
Pio
Very true. IMO dont go over 2,500 with stock run-flats (even that ight be too aggresive and smoke them), if you get a stickier tire go for 3,000 plus. A stall converter, gears and tires should lower your e.t.s by 1/2 second.
Old Aug 21, 2005 | 01:02 AM
LS WON's Avatar
LS WON
Default Keep it factory stock and you will have less problems in the long run
The way your car is now you will probably beat most of the M-6 drivers unless you come across a great driver. You can't beat an automatic shifter in straight line and it doesn't miss shifts or mess up like a driver can in a manual. Your car is plenty fast
And don't forget the other part of the equation is to get the power to the ground where and when you need it most and you have to know how to launch the m-6 just right to get the power to the ground where you need it otherwise you will be left behind just spinning your wheels. For some drivers to get their M-6 to perform like this they end up abusing their manual transmissions end up with more problems and blaming it on the clutch when it is the driver skills that dictate a perfect take off launch.
Old Aug 21, 2005 | 01:15 AM
FLC6's Avatar
FLC6
Juice
Old Aug 21, 2005 | 01:26 AM
LS WON's Avatar
LS WON
Default I would not expect the engine to last that long.
Originally Posted by FLC6
Juice
Putting all of this power in you will end up scarficing less life out of your motor and other related parts.
Old Aug 21, 2005 | 01:30 AM
FLC6's Avatar
FLC6
I know.
Old Aug 21, 2005 | 11:00 AM
miac6's Avatar
miac6
thanks reply #6 I will take your good advise hope your having a great weekend.
To a4 c6
