Nitrous Window Switch Install
Old Aug 27, 2005 | 09:05 PM
CSICK's Avatar
CSICK
Default Nitrous Window Switch Install
IM HOPING SOMEONE OUT THERE HAS INSTALLED A MSD WINDOW SWITCH ON THE C6 AND THAT CAN TELL ME WHERE IT HOOKS UP TOO?????
Thanks ,Don
Old Aug 27, 2005 | 09:30 PM
FLC6's Avatar
FLC6
Don put this in the Nitrous section.
Old Aug 27, 2005 | 11:31 PM
SpinMonster's Avatar
SpinMonster
Pin number 48 on the blue connector / PCM. Set it for 4-CYL operation.
Old Aug 28, 2005 | 12:21 AM
FLC6's Avatar
FLC6
Didn't work for my BMN window switch though.
Old Aug 28, 2005 | 02:33 AM
SpinMonster
Mine is working there along with my shift light (Raptor). It is the tach signal. May be an issue with comptability with your window switch. Some msd users report that it must be sent back to work with the LSx motors but mine worked out of the box as did my shift light.
Old Aug 28, 2005 | 12:15 PM
FLC6's Avatar
FLC6
Spin, I think you are right.
I am going to try to hook it up via a coil. I don't know what to set it at though. 4 6 8.
I will try all of them. Too bad the BMN doesn't have a 1 setting.
To Nitrous Window Switch Install
