Header Question
Comments/advice please.
Any other headers worth considering?
And what do I have to do with the O2 sensor to get the most benefit?
Thanks guys
Thanks guys
Had KOOKS on my C5. Not much written about headers for the C6.
Other than the engine fires on MN6 C6s, associated with the Dynatechs , a product I would avoid like the plague.
The big selling point over on the C5 side of things for the LGMs was their ability to improve torque across the RPM range. Not just peak numbers. Don't know if this is the case or not for their C6 application. This is great if you want to feel the difference in normal driving and not just at the drag strip.
The KOOKS performed flawlessly on the drag strip and were second to none. However during "normal" driving the difference was barely noticable. You had to get up into the RPMs to get the full benefit. SInce I no longer drag race, it is not so important to me.
Points to consider:
Are the KOOKS stainless all the way back? If not, this may be something you wish to consider. May be worth a little bit more to have a totally stainless system. I loved my KOOKS, but if I were doing headers on my C6, which I am not, I would be willing to pay a bit extra, say $200.00, for this advantage alone.
Long tubes are not long tubes. Go stainless steel if you can and consider the diameter of the x pipe. Also I would stick to either LGM or KOOKS if I were looking for headers.
Hope this helps.
Points to consider:
Hope this helps.
Jokes aside - DynaTech includes a bracket to hold the clutch slave line clear of the header (as this was the source of the fire, not the header itself). There are "supposedly" 2 models of SuperMaxx - Manual & Auto trans models that take clearances into account.
After installing a set of these myself, when the instructions (and COMMON SENSE) are followed - when it says to make sure that all wires, cables, hoses are clear of the headers - it would behoove you to do so. This was the case in the aforementioned fires - someone didn't do thier due dilligence in assuring that nothing was in contact with the header. The fires were as much the fault of the installer (if not MORE), as DynaTechs. I took extra care to make sure the 02 extensions, clamped the clutch hose, and went back thru my installation carefully to make sure I eliminated the possibility of anything actually coming in contact with hot pipes.
That being said - the pipes are of top quality, installation instructions are detailed and complete, the installation of the X-pipe/cats are clean, they're decently priced, and as part of the "proof of the pudding":
Bone Stock: 336
Stinger/SuperMaxx/GHL untuned: 343 conservatively tuned: 371
#'s talk, availability talks. Someone in the forum had posted that they laid a new LG system & SuperMaxx system side-by-side before installation, and the SuperMaxx was heads over the LG in quality.
Rick
Edit: add dyno chart - dyno's may be subjective, but those numbers aren't "variations" between pulls. This was a conservative tune - Jeremy, Norris, Zimmer, etc., could likely have eeek'd another 10-15HP out of it. Also ran @ 97 degrees/98% Humidity (just stopped raining).
Bone Stock: 336
Rick
Most of that 35hp gain came from the headers and tuning without a doubt Geez
One other thing to consider is the availability of the headers. I, like numerous others, believe that LGM will probably be the best available which is why I ordered them. However, I, again like numerous others, am still waiting for Borla to make them and ship them to LG Motorsports for further shipment to us.
Luckily, I did not order as early as some (I've heard and read of people who have had their order in since February!) but it bugs me to have my credit card charged and still be waiting two months since I ordered with no one at LG able to give me a decent status report.
If you want them now, go with Kooks or DynaMax, otherwise get in line buddy.
Bone Stock: 336
Rick
Homemade catback, Dynatech headers, Lingenfelter CAI, NO TUNE = SAE corrected 378.6 RWHP and 370.6 TQ. The headers added 40#TQ at 3000RPM and 15#TQ at 5000RPM. The CAI gains were all above 3500 RPM.
You ran 378 WITHOUT a tune? Damn, I was ROBBED...
You running cats, or a straight pipe?
Rick
Thanks Ben
I did hear that they had addressed these issues with the C5s however.
Rick
I'm hoping for another 10-12 HP from a tune once the tuners get a better setup than the existing "Beta" tune.
........................................ ............Scott
