From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
hurst shifter question
I recently installed a hurst shifter (the c5 version) in my c6. Very nice and a big thanks to Lager for the detailed directions from his install. I did, however, find some slight differences in the process but all in all his directions provided a good roadmap.
First, let me say, the shifter is excellent and a huge improvement over the stock unit. The only issue I currently have with the hurst is the stiffness. The shifts are nice and positive but the left to right movement isn't as free as the stock unit. I switched the 'springs' to the lighter ones but it's still a little stiff. I like a 'loose' shifter, one that can be controlled with just wrist action. Instead of using two springs per side can I use just one ? or will it loosen up with time ?
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
It will loosen up with time but, not alot. That is what you want , it allow you to nail the 2-3 shift perfectly because the springs help to force it into the proper position for third...Now just get the Team Voodoo **** and you will shift like magic....
thanks, yes it is allowing for really nice shifts. the only problem I had was fifth to sixth (hit fourth twice instead - oops), and finding first has been a little iffy, but it's getting better. Guess it's just getting used to the shifter. All-in-all it has made shifts much smoother and quicker. I just a tad hesitent to try my sixth to fourth downshift but I'm sure once I get the hang of this shifter it won't be a problem. btw: I picked up a Kirba shift **** with 6 speed pattern.
A couple of forum members have taken the springs out completly. Me? I sold it and went B&M. The bushings that they include in the kit make a big difference (especially since mine were shot after 3K).
Originally Posted by tfenton
I just ordered the B&M, too. My hurst had too much vibration under heavy load (really bad). I'm hoping the B&M will be better.
when what how did the vibration appear ? I've haven't seen / felt any abnormal vibration from mine. I just ran it up to 122 mph and didn't notice anything from the shifter. Would downshifting into fourth from sixth @ 78 mph then flooring it be sufficient load to cause the vibration ?
2nd & 3rd gear ... usually when I'm giving it everything it's got. Around town it's awesome but since I leave early am and my drive to work is open highway I hit it hard. It's a bummer since I love the tight, short shifts.
Maybe it's my install but I followed a few posts here flawlessly. The only thing I did not do is create/buy & install an extra rubber plug. Maybe that's it ...
