Elite Alum Pedals - Installation Problem
Getting the stock gas pedal pin out was a problem but I eventually got that accomplished with a C clamp. But I encountered another small problem that I don't believe has been mentioned by anyone.
I installed the gas pedal per instructions with the help of all of the wonderful installation photos on the Elite website. No problem at all in doing the installation.
But, the gas pedal had a lot of side-to-side play, much too much! The instructions mention that you should: "be sure the tension spring falls into the groove machined in the shoulder bolt". But there was no way that the spring could fall into the groove because the thickness of the stock gas pedal lever was such that the spring could not fall into the groove. I did a measurement and discovered that the shoulder bolt groove had to be 1/16" further to the right in order for the spring to fall into the groove. Not much, but it is the difference between a bad or a good installation.
I came up with a quick fix by using a metal file to take off about 1/16" from the inner side of the Elite pedal where the shoulder bolt comes through. That enabled the gas pedal lever to move slightly more to the left as the pedal was installed, and the tension spring fell nicely into place. There was no more side-to-side movement. I can only assume that the thickness of the C6 gas pedal lever may in some cases vary slightly and prevent the Elite pedal from seating properly.
The Elite pedal setup looks great and I am happy with the result. Just be aware that you could encounter a similar problem. It is a simple fix once you figure out what is wrong.
Like a loud exhaust, the "temporary fix" is just to turn the stereo up...
Rick
