Sway bars
Old Sep 26, 2005 | 10:06 AM
SpinMonster's Avatar
SpinMonster
Default Sway bars
Are the hotchkis sway bars available. The T1's are available for the C6 but they mat be a bit much for the street.
Old Nov 8, 2005 | 06:55 PM
SpinMonster
Anyone? BMR?
Old Nov 9, 2005 | 09:21 AM
Turbooo2u's Avatar
Turbooo2u
Did you try calling Hotchkis? 1-877-466-7655.
Old Nov 9, 2005 | 09:27 AM
ricatthebeach's Avatar
ricatthebeach
Are T-1's available for the c6? If so, where can they be purchased?
Old Nov 9, 2005 | 11:26 AM
davidfarmer's Avatar
davidfarmer
they look like they may be interchangeable (C5/C6), but I haven't actually tried it yet. If so, that would open lots of options.
Old Nov 9, 2005 | 11:34 AM
SpinMonster
Yes, they said they are testing them for rate now and January/February is the stated release date. I used the BMR's on my C5 and I would use them if they were available. I know the sway bars are the same for the C5 and C6 if you change the mufflers to a smaller size one.
The front sway bar is identical but the rate may be different.
Old Nov 9, 2005 | 12:27 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Spindoctor is right, the front C5 t-1 bar will go on. It is a very tight fit because of the fan shroud. The rear bar will go on if you switch out to BandB route 66 (i'm sure other will fit but I don't know forsure)
Randy
Old Nov 9, 2005 | 08:09 PM
Gene@FredBeans's Avatar
Gene@FredBeans
I can get the C6 T1 bars. I believe I sold them for 750 shipped.
-Gene
Old Nov 10, 2005 | 02:31 AM
SpinMonster
Gene, I ordered a Z06 rear bar from you today until the T-1's are available for the C6 without having to change the exhaust.
To Sway bars
