c6 cam base circle same as ls1?
Old Sep 28, 2005 | 07:48 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default c6 cam base circle same as ls1?
is the base circle diff on the ls2 cam?
Old Sep 29, 2005 | 03:15 PM
SpinMonster's Avatar
SpinMonster
Originally Posted by connecticut
if the base circle diff on the ls2 cam?
same...02 z06 cam was smaller not the 01
Old Sep 29, 2005 | 03:21 PM
SteveDoten's Avatar
SteveDoten
ok, i will assume the 01 z06 cam is in the ls2?
Old Sep 29, 2005 | 04:02 PM
andreas g.'s Avatar
andreas g.
Default you're correct
that cam is 204/211 525/525 116.5 lsa's
Old Sep 29, 2005 | 11:44 PM
hennytime's Avatar
hennytime
its too bad you cant use the ls7 cam for our gen 3 motors...
To c6 cam base circle same as ls1?
