ls2 cam install help; what puller to use?
Old Oct 1, 2005 | 05:23 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default ls2 cam install help; what puller to use?
the rack, rad is out; crank bolt is out; what puller are people using to get the crank pulley off; i've got the ls1/6 know how, done a few of those; the ls2 is WAY DIFFERENT, thanks, 860-989-8972 if you got the kent moore gm puller
Old Oct 1, 2005 | 10:48 PM
SteveDoten's Avatar
SteveDoten
nevermind, got the pulley off, cam is installed
Old Oct 2, 2005 | 12:34 AM
cerino2000's Avatar
cerino2000
well what did you use?
Old Oct 2, 2005 | 08:57 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Old Oct 2, 2005 | 09:14 AM
SteveDoten's Avatar
SteveDoten
a smaller puller than the one used on the ls1, i'll try to put together a ls2 cam install guide later on, the engine is almost the same(cam sensor up front, reads off the sprocket?), but getting there is TOTALLY DIFFERENT xmember needs to be dropped for the rack
Old Oct 2, 2005 | 10:12 AM
RyanC7's Avatar
RyanC7
Sweet looking forward to it.
To ls2 cam install help; what puller to use?
