Disable DRL's
Old Oct 5, 2005 | 07:45 PM
aaaaa's Avatar
aaaaa
Default Disable DRL's
Is there a fuse I can pull to disable the DRL's like on the C5?
Old Oct 5, 2005 | 07:47 PM
Vette_DD's Avatar
Vette_DD
What kind of car are you talking about?
If you're talking about a C6, the answer is no.
The reason I asked is that your profile doesn't show a C6 and some folks have been known to post in the wrong section.
Old Oct 5, 2005 | 07:50 PM
aaaaa's Avatar
aaaaa
Thanks for reminding me-i should update that.
Old Oct 5, 2005 | 08:02 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
You can turn them off after you start the car if you want.
Old Oct 6, 2005 | 12:53 AM
shopdog's Avatar
shopdog
No, they double as your turn signals, so if you pull a fuse, you'll lose turn signals too.
To Disable DRL's
