need advice on air filter maintenance
Old Oct 6, 2005 | 08:54 AM
bj33813's Avatar
bj33813
Default need advice on air filter maintenance
I have the halltech stinger. When should I clean it, and what should I use to clean it, and finally, how is the best way to re-oil it ?
Thanks.
Old Oct 6, 2005 | 02:55 PM
andreas g.'s Avatar
andreas g.
Default when to clean
this is a subjective evaluation of how dirty it is. No set rule. As for cleaning didn't they give you a kit, cleaner and re-oiling spray? If not, simple green and warm water will clean it well enough, but each manufacture usually has there own special oil, K&N,Blackwing, etc. Have had both..
Old Oct 7, 2005 | 08:44 AM
bj33813's Avatar
bj33813
No, for $500 you don't get a cleaning kit or oil...LOL...but I'll try the simple green when the time comes, and just use 30 wt oil to oil it.
Old Oct 7, 2005 | 01:30 PM
andreas g.'s Avatar
andreas g.
Default No No!!
That kind of oil will clog up the filter. Call them and ask if they have an oil or can reccommend one. If not, then I would use K&N's oil in the aersol spray can, not the pump spray. It also sprays much better than the Blackwing oil. It spits oil ,not a fine spray like K&N.
andreas g.
Old Oct 7, 2005 | 08:56 PM
RBYCC's Avatar
RBYCC
andreas g.
Much worse then clogging the filter, it will gunk up the MAF and cause poor performance . Even the recommended filter oil will affect the MAF if too much is used. The high performance filters go a long way before they need cleaning.
Old Oct 8, 2005 | 12:18 AM
dgcarver's Avatar
dgcarver
andreas g.
I thought spraying with WD-40 worked pretty good? Any thoughts or feedback?
Old Oct 8, 2005 | 08:14 AM
bj33813's Avatar
bj33813
Thanks for all the great advice guys...I wasn't aware that a spray was made but will sure look for it. I guess the idea is to get one that is really light ?
Old Oct 8, 2005 | 09:20 AM
GaryZ06's Avatar
GaryZ06
I do this on my Vararam filter.
To need advice on air filter maintenance
