Header installation ?
Old Oct 12, 2005 | 04:35 PM
haljensen's Avatar
haljensen
Stock bolts are a 13mm head. Dynatech supplies new bolts with a 10 mm head and recommends using anti-seize.
Old Oct 12, 2005 | 05:11 PM
jjas's Avatar
jjas
Just installed Dyna Super Max an B@B exhaust on my C6. Did the installation myself. Put the car on jack stands about 16-18in off floor. Worked great. ONE WORD OF CAUTION YOU WILL NEED SOMEONE TO HELP REMOVE AND INSTALL THE HEADERS. If not you will risk breaking a spark plug. I did break a spark plug. Good luck and have fun.
Old Oct 12, 2005 | 07:59 PM
aaaaa's Avatar
aaaaa
Thanks for the tip!
Old Oct 19, 2005 | 02:31 AM
Michael A's Avatar
Michael A
Is there any reduction in ground clearance with either the Kooks or LG headers?
Old Oct 19, 2005 | 02:45 PM
stinky's Avatar
stinky
Nope. Tucked up in there in the stock location.
Old Oct 19, 2005 | 07:09 PM
Irish Whiskey's Avatar
Irish Whiskey
I wish you luck with the Kooks - I had these installed on C5 and have wished I had done the LG's - no dyno increase, no strip increase, ouch!!
Old Oct 19, 2005 | 07:31 PM
Miaugi's Avatar
Miaugi
Hindsight is always 20/20 huh? When I did my C5 I removed all the spark plugs, and also put an exhaust bolt in front of the temp sensor to protect that from getting whacked.
Hope you got it all fixed without too many more headaches?
Old Oct 19, 2005 | 07:33 PM
Miaugi's Avatar
Miaugi
Originally Posted by stinky
Headers are stainles, x-pipe aluminized. Swaintech did the coating, outside only.
Thanks!
Old Oct 19, 2005 | 07:41 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
I thought you would have dumped the KOOKS and gone ahead and pulled the trigger on those LGs by now.
How long has it been, what 5 or 6 months since you installed the KOOKS and got no gain?
It certainly would be interesting to see how much, if any, gain the LGs would get you above the KOOKS.
Old Oct 19, 2005 | 07:59 PM
jschindler's Avatar
jschindler
Originally Posted by Nicodemus
They are 13mm. I installed a set of kooks a few weeks ago, they fit perfectly. It was a very easy install.
I guess this means that the "adult response" was wrong
Old Oct 19, 2005 | 08:02 PM
jschindler's Avatar
jschindler
Now that's really odd! That is a big difference in head size. Sound to me like the 10mm head would not be much bigger than the thread OD.
Old Oct 20, 2005 | 10:19 AM
haljensen's Avatar
haljensen
The threaded portion of the bolt is 8mm, both the stock and the Supermaxx bolts have flat washers formed to the bolt head so they have almost equal bearing surfaces. Don't understand why the smaller bolt head, there's lots of clearance from the header tubes to all the bolts. No need for u-joints or wobble sockets, I could get a torque wrench on every bolt.
Old Oct 20, 2005 | 11:15 AM
  #33
jschindler's Avatar
jschindler
Good information. Thanks
