2006 C6 ratios?
How will it effect 0-60 performance and/or top end relative to 2005 automatic or 6 speed manual ( 3.42 ratio )?
6 speed standard...............6 speed Z51............................A6.....
...................Final Ratio................Final Ratio..................Final Ratio
1st; 2.66X3.42= 9.10........2.97X3.42= 10.16.......4.027X2.56= 10.31
2nd;1.78X3.42= 6.09........2.07X3.42= 7.08.........2.364X2.56= 6.05
3rd; 1.30X3.42= 4.45........1.43X3.42= 4.89.........1.532X2.56= 3.92
4th; 1.00X3.42= 3.42........1.00X3.42= 3.42.........1.152X2.56= 2.95
5th; 0.74X3.42= 2.53........0.71X3.42= 2.43.........0.852X2.56= 2.18
6th; 0.50X3.42= 1.71........0.57X3.42= 1.95.........0.667X2.56= 1.71
Look at 1st gear; Z51 is 10.16:1, A6 is 10.31:1.
Look at 6th gear; Base Mn6 and A6 are the same final ratio.
Certainly being able to market the six speed auto as a "world class" transmission can't hurt - but is more likely to be a selling point in cars like the Cadillac STS which goes head to head against a variety of premium European and Japanese sedans. Truthfully, the A6 is just a gift to the Corvette. No way would they have developed it for the small numbers that the Corvette will use.
The biggest benefits will be realized next year when the new Tahoes, Suburbans (and their "twins") come out with the A6 - followed by the new pickup trucks a year later. That will make a huge difference in GM's ability to meet new CAFE requirements for trucks and truck classified SUVs.
He's probably right, the ratios we get are for a tranny that will be used in many applications; not ideal for us. Bummer.
All it'd do in a light Corvette with TC turned off is smoke the tires, and we don't need the extra torque multiplication to do that. We have enough trouble getting off the line quickly without smoking the tires as it is.
The other gears, after the torque converter locks up at 1:1, are all taller than either MN6 or the A4 with a 3.15 rear, so the A6 won't pull harder once rolling than the manuals or the old auto. The GM Powertrain hook graph was right.
Note that this also explains why, in sport mode, the A6 will start off in second unless you force it down to first. In second, with the torque converter multiplication, you still have a final ratio of 12.1. Once the revs come up enough for the torque converter to lock up, of course, you're down to 6.05 in second, and the following gears also offer less multiplication than the corresponding MN6 gear.
I don't see it being too hard to launch these cars, granted, I've never had one. But my truck put down over 600ft lb of torque to the wheels, and I manged to get it out of the hole with a 1.79 60'....on Goodyear f1's on a consistant basis.
I'm looking forward to seeing what I can do in a vette.
A4 315 | 9.64 5.13 3.15 2.21
A6 256 | 10.3 6.05 3.92 2.95 2.18 1.71
Considering a locked TC, all of the A6 gears are actually shorter than their respective A4 gears with either 2.73 or 3.15 rearend by a significant margin. It should pull harder than either A4 in any gear.
