Shifting/3rd Gear ??? - HELP!!! Please.....
Old Oct 17, 2005 | 06:19 PM
AutoCutter's Avatar
AutoCutter
Originally Posted by SickRick
True neutral, is centered at 3-4 (6 speed, remember?). So you would have to pull to the left for the 1-2 shift. The 1st gear from neutral issue has to do with the 1st gear synchro. Since it's documented in the owners manual, I guess you could call it a FEATURE. There is a TSB on it though, that calls for replacing the 1st gear synchro. Usually, hitting the clutch 2x allows you to get in, or going into 2nd then first, or going into 2nd -> moving forward a little -> then into 1st. All of these work to some degree, but alot of times it just won't go into first and I just start out in 2nd, lest the yahoo behind me nails me in the rear...
Rick
There's a little side to side adjustment on the shifter carrier as well as fore and aft. I know about the synchro problem, but the first install attempt was prefect, but I had a real bad rattle issue. The second install using the neutral pin got rid of the rattle, but it takes a strong pull to the left to get it in to 2nd as well as 2nd has become notchy so I have a bit too much fore adjustment as well as side.
