stall speed
Thanks in advance
Thanks in advance
When the torque converter reaches stall, it no longer slips like a clutch, and torque multiplication falls to 1x. (Note that there is still some slip due to fluid shear, and modern transmissions employ a mechanical lockup at this point to eliminate slippage completely. This improves fuel economy, and reduces heat buildup in the transmission.)
Now if we raise the stall speed, we allow the engine to rev higher into its power band before being fully loaded. This gives a stronger launch. This is great for drag racing. But on the street we cruise at 1500 to 2000 RPM, and a 4000 RPM torque converter would still be acting as a fluid clutch, slipping and wasting gas, and generating excess heat in the transmission. That would be bad. So torque converters for street cars have stall speeds in the 1200 to 1600 RPM range.
Talk to the experts here are the links
http://www.protorque.com/prodln/pl_po.htm
http://www.prodyno.com/Product/Produ...x?id=43&cid=17
http://www.prodyno.com/Product/Produ...id=17#overview
Cajun
Cajun
