Nitrous
Old Oct 20, 2005 | 01:03 PM
Tampa Vette's Avatar
Tampa Vette
Default Nitrous
What is the best nitrous kit out right now? Any info would be appreciated, such as what kit and any recommended accessories, etc.
Thanks in advance!
Old Oct 20, 2005 | 02:01 PM
dshaner1's Avatar
dshaner1
Thanks in advance!
I believe its NOS that has one that comes with a throttle body and everything so you don't need to tap into your existing one. I'd run a search for that one.
Old Oct 20, 2005 | 02:02 PM
dshaner1's Avatar
dshaner1
Found this link http://forums.corvetteforum.com/show...0&forum_id=123
Old Oct 21, 2005 | 09:14 AM
Tampa Vette
Thanks dshaner1.
Old Oct 21, 2005 | 09:37 AM
haljensen's Avatar
haljensen
With no external throttle linkage how do you mount a WOT micro switch? Under the gas pedal? I already have no traction is first gear, is there some way to trigger the N2O only in second and higher gears?
Old Oct 21, 2005 | 11:36 AM
Tampa Vette
I would like to have a progressive controller. You can adjust the nitrous to come on progressively over a period of time. I could program it to come on 2 seconds into the run at say 25% (on a 100 shot) and work up to 100% by say 10 seconds, or less, depending on traction, etc.
Old Oct 21, 2005 | 07:33 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Use a digital window switch from Jegs. You can program it to come on at higher RPM (say 3800) or you can shoot it at 3000 RPM if you want to get some serious jump out of the car with a stock converter.
Cajun
To Nitrous
