C6 spolier installation?
Old Oct 23, 2005 | 10:20 PM
Coupebill's Avatar
Coupebill
Default C6 spolier installation?
C6 spolier installation? Has anyone installed a body color matched spoiler on their C6? If so can you pass on the installation steps? Thanks, I can't stand the factory installed black one!
Coupebill
Old Oct 23, 2005 | 11:26 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Coupebill
Really simple. Remove the inner tail lights (one torx screw at top of lens). Unplug the electrical connectors - you have to squeeze then pull). Then reach into and use a small wrench (I'm thinking it was 10mm) to loosen the nuts. You won't have to loosen them much. Mine were just a touch more then hand tight. Then unscrewed by hand.
You have to disconnect the brake light - again squeeze and pull. Four nuts hold the spoiler on. Once they are all off, you have to transfer the brake light to the new spoiler. The two inside mounting studs hold it on. They just screw into the plastic so don't overtighten them. They have a torx end but I just used a set of vise grips.
Then reverse removal steps to reinstall everything.
Reasonably simple install.
Old Oct 23, 2005 | 11:27 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Easiest install ever!
Just pop out the inner taillights (1 torx screw) and reach inside to access the 4 nuts. Spoiler pops right off.
Enjoy
You just beat me to it Snake Driver
Old Oct 26, 2005 | 08:03 PM
Coupebill's Avatar
Coupebill
Thanks for the response it sounds easy enough!
Old Nov 1, 2005 | 08:46 AM
vetdude's Avatar
vetdude
Where's the best place to get one?
Old Nov 1, 2005 | 08:55 AM
not08crmanymore's Avatar
not08crmanymore
Default get one
try chevy.
Old Nov 2, 2005 | 06:53 PM
TexasTechZ06's Avatar
TexasTechZ06
I got mine from Nate at Corvette Garage. He has a bunch and cheap!!!
Old Nov 2, 2005 | 07:13 PM
novocaine's Avatar
novocaine
Default spoiler
Coupebill
How can that thing even be called a spoiler? does it serve any function at all? It is soooooo small and doesn't look like it has the ability to function at all.
Old Nov 2, 2005 | 09:41 PM
Coupebill's Avatar
Coupebill
"Where's the best place to get one?"
I purchased the color matched spoiler and door handles from the Chevy dealership where I purchased my C6.
Old Nov 2, 2005 | 10:25 PM
thejerseydevil's Avatar
thejerseydevil
I got mine from GMPARTSDIRECT.COM. Saved over $50 from everyone else.
Easy to install, took about 30 minutes. Someone posted instructions but remove the right and and left inner tail lights and unscrew from the inside. Just be careful not to drop the screws.
Good luck.
Old Nov 4, 2005 | 01:06 PM
X-Blue-vette's Avatar
X-Blue-vette
Hi, does this spoiler lhave the LEDs that run the length of the spoiler or is it like the stock light. Thanks
Old Nov 4, 2005 | 08:50 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
You can get either.
Old Nov 5, 2005 | 06:21 PM
Coupebill's Avatar
Coupebill
Default Completed installation!
It took all of 45 minutes to change out the door handles and rear spoiler. One item of note; you will need a 4mm socket to remove the 4 studs that need to be transfered to the new spoiler.
Thanks for the advice!
To C6 spolier installation?
