Fuel Rail Cover Removal Help
Old Oct 31, 2005 | 06:03 PM
SA HEAT's Avatar
SA HEAT
Default Fuel Rail Cover Removal Help
Anyone know how to get the driver's side FRC off? Do I disconnect the fuel line (If so, how) or do I try to feed it through the cut out in the cover while attached? (doesn't look like it will do it without chewing the cover up). Thanks.
Old Oct 31, 2005 | 06:07 PM
Brett Hunter's Avatar
Brett Hunter
It feeds through the cut in the cover. I taped the fuel line to prevent it from scratching the painted covers I installed.
I didn't notice any damage to the stock cover when I removed it before taping the line though.
Old Oct 31, 2005 | 06:09 PM
SA HEAT's Avatar
SA HEAT
I'm gonna go try it....... be right back.
Old Oct 31, 2005 | 06:12 PM
icedancer's Avatar
icedancer
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
Use blue 3M painters masking tape on the fuel line AND on the sides of the slot. The FRC bends so you can wiggle the cover off of the fuel line, with care.
Be sure to use tape on both the fuel line and the FRC slot, and two thicknesses to be safe.
If your FRCs are not yet painted, any masking tape will suffice - if they are painted already, or you are installing new ones that are painted, be sure that the masking tape is LOW TACK (ie. easily removed).
Old Oct 31, 2005 | 06:30 PM
SA HEAT's Avatar
SA HEAT
Thanks, Brett. The tape worked.... no scratches. I love this forum!
icedancer, I didn't tape the FRC side, but would have if I'd seen your post before I went outside..... maybe I got lucky. Thanks!
Old Oct 31, 2005 | 07:46 PM
Turbooo2u's Avatar
Turbooo2u
Before I put on my new painted covers, I broke the driver's side black cover. I never did learn some patience.
Old Oct 31, 2005 | 09:32 PM
cerino2000's Avatar
cerino2000
Taking off the factory ones that you are not worried about isn't too bad. Putting on nice painted ones can be nerve racking. I bought the $5.00 tool from AutoZone and after de-pressurizing the fuel rail, pulled the line from the firewall side. Even that was a minor PITA because the cover kept wanting to get hung up on the fuel line. All is well after a little patience.
Old Nov 1, 2005 | 01:51 AM
not08crmanymore's Avatar
not08crmanymore
Default painted frc's...
I've had mine for a month now and haven't even put them on yet because I don't want to break something!!It's never as easy as it looks!!!
To Fuel Rail Cover Removal Help
