C6 Brake Bleeding
Old Nov 1, 2005 | 08:42 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Default C6 Brake Bleeding
If I remove one caliper on my C6, after re-installing do I have to bleed all four brake lines, or just at the one I removed? Thanks, Kevin
Old Nov 1, 2005 | 08:46 PM
davidfarmer's Avatar
davidfarmer
as long as the rest of the system still have fluid in it (ie, the master is still full), just bleed that corner. If there is ANY chance the fluid level dropped in the master, you need to bleed everything, possibly even the ABS controller.
Old Nov 2, 2005 | 06:37 AM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Thank you Kevin
Old Nov 2, 2005 | 03:58 PM
C8-Vette's Avatar
C8-Vette
If you ever have to bleed the entire system , always start with the wheel furthest from the master cylinder and work your way to the one nearest the MC. I flush the fluid on all my cars once a year. Never had a wheel cylinder or master cylinder failure in 50 years. Moisture finds a way of getting into the fluid.
Old Nov 4, 2005 | 10:40 PM
54greg's Avatar
54greg
I've done all my own brake maint for years. Changing and painting calipers, bleeding has never been a problem. If the complete system has to be bleed, how do you bleed the abs controller?
Old Nov 5, 2005 | 07:36 AM
davidfarmer
Usually you can flush the system with doing an ABS EBTCM bleed, BUT if you ever do get air into it, it can only be purged using the GM Tech2
To C6 Brake Bleeding
