Looks to me like they install new sleves with 1" block spacers. Hard to tell what the specs are, but i'm thinking 4.5" stroke and somewhere around 4.2 bore.
Thats a whole lot of SB girth, specially with the 4.4 bore spacing.
Just saying “500ci” almost makes me orgasm!
However, that’s way to much stroke I’m afraid.
I dunno what kind of power we’ll see out of these setups, but I doubting it will be much more than 427ci setups.
Torque will be sick of course. I also don’t know about long term reliability with such extremely long strokes because of side loading issues.
What we need is a new aluminum BIG BLOCK.
Why can’t an aftermarket block company come out with one damn it!
This way it could be bored the hell out (something like 4.5” bore would be nice!). Then insane power will be available NA.
A 4" stroke crank already puts a pretty severe side load on the pistons as they come out of the skirting.....where/how are they finding the extra 0.50???? Crank balance bobs must be smaller?
I personnally would not try and make any significant power/RPM with this motor, it is hard enough to get the 4" factory bores to stay true under high loads.
My 4.100 block is collecting dust after some NOS abuse caused the sleeves to drop.
If you look at the typical endurance race motor they are almost always big bore short stroke.......
My $.02
Sleeves dropping? That doesn't sound good. My LT5 has a 4 inch bore and a 4.125 inch stroke - but the sleeves cannot move as they are a wet sleeve design and they have a double radius, with the larger radius seating firmly into the block itself. The pistons drop down out of the sleeves on the bottom end almost half way - but these motors have been working reliably since 97 - with about 60 versions total in service. What's more - the idea that it won't spin to high rpms is bs. My redline is at 7300 rpm, and some have theirs set to 8000 rpm - it is governed by the accessories, which don't like high rpms. I eagerly await the results of this one!
