okay i'm take my car to service to see whats what about this rear, anyways someone told me if the Battery is disconnected for 24 hours it will reset the black box & they can't see how it blew?
if this is not how you do it could someone help me out here & fill me in?
Once power is removed, the car has no way to know how much time has passed. So if this 24 hour disconnect did work, it doesn't BTW, a 30 second disconnect would work just as well.
But it won't work, because the car history is stored in nonvolatile memory, same as the tune or other settable parameters. AFAIK the only way to clear it is to overwrite it.
The car does this normally. The history memory is arranged as a circular que. After 50 complete run cycles, the last event is overwritten and new information has filled the que. A run cycle is a cold start followed by 5 minutes at 55 MPH.
...After 50 complete run cycles, the last event is overwritten and new information has filled the que. A run cycle is a cold start followed by 5 minutes at 55 MPH.
shopdog, does this mean if I drive my car 1 time everyday for 2 hours and I get past 55 mph for 5 minutes, the black box stores 50 days (100 hours) of info?
I would think it would be more like a continuous loop of the last 60 minutes of run time?
So are you saying that they may be able to tell what the car was doing in terms of launch RPM, etc when it went down?
If so what other parameters are stored in the car's novolatile memory?
I think his question was about the "black box", not the ECM. It's my understanding that the black box only has a minute or so of memory and is continually overwritten, it's just for accident re-constuction.
The ECM can be changed, thats what tuners do. Check Engine Light Codes in the ECM can be erased by many scan tools OR by disconnecting the battery OR by pulling the ECM fuse. Previous CEL codes require the drive cycle to clear them even if you cleared the codes by any of the three methods above.
The black box is part of the airbag system, it records a minute's worth of info when there's an accident (air bag deployment or near-deployment). This is stored in non-volitile memory. It probably doesn't matter for this case; you might want to destroy it after an accident.
The ECU may store snapshot information about the last code event, depending on the code. This is stored in semi-persistant memory, which probably would be erased by powering off the ECU for a long enough time. Or can be erased by resetting the code using a scan tool.
If the car stores more info they aren't admitting it, so the dealer probably doesn't know about it either.
I know I was a little worried about them pulling a log of my car when I had the rear replaced, especially since they directly asked if I had been Drag Racing and I said NO, but really had. :o
As it turned out, they either didn't look or didn't care. I got my car back yesterday with a new rear, no more questions asked...
It only stores snapshots, when a code is generated, or when a required run cycle test sequence is completed. It is not a continuous log.
The "black box" stores the last 6 seconds before airbag activation. It requires a special tool to access it.
These same folks barely capable of changing oil without mucking it up have no ability to read black box data. That's only available to OEM engineers and law agencies by subpeana. You need the secret X and O decoder. Doesn't sound like you had an SIR deployed crash anyway, there would not be any data to read.
The data available via Tech II is just the basic data stream and DTC information. There is no DTC for drag racing, so these monkeys just look for signs like wheel wells full of rubber, dial in time on glass, time slips in the glove box, and their all time favorite - Nitrous holes in the intake (and pistons sometimes) and bottle mounting bracket holes.
Bring it in relatively stock and clean, should have no problems.
