What octane do you guys use?
Old Nov 5, 2005 | 12:56 PM
c5 devil's Avatar
c5 devil
Default 98
I use 98 octane here........and nothing but 98
Use the best when you bought the car you did not buy a echo you bought a vette...so, money shouldn't be an issue...my .2$
Old Nov 5, 2005 | 01:17 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
only tier one premium for me. unless I'm about to be stuck in bfe, then it's only 5 gallons of the best around, that should get me 100 miles (5*20mpg).
Old Nov 5, 2005 | 01:19 PM
Zig's Avatar
Zig
Originally Posted by VetVetter
Nowadays, all retail gasoline contains additives ... the gasoline itself is the same in each area of the company for all the gas retail companies ... what sets them apart is their additive package: notice how they advertise now.
Perhaps a while back, Amoco didn't use additives when other started but I know for a fact they (BP) does now for sure ... they claim theirs is the best - blah, blah , blah
Especially nowadays with the lower octane gasoline, I would not want to use a fuel without additives - they serve to keep your engine cleaner, fuel burn more efficiently, help keep filters and fuel lines cleaner, etc
just food for thought
Chevron has the best fuel with the greatest coverage. yes, you may find a few with supposed better gas but they aren't as abundant.
Old Nov 5, 2005 | 01:54 PM
sanfranman's Avatar
sanfranman
Take care of your car. Use the premium octane recommended by the manufacturer (here in CA I use 91 the highest available), better yet stay with the 3 major brands. I rotate between each brand every 5000 miles as each brand uses slighltly different additives to benefit the engine.
Old Nov 5, 2005 | 04:18 PM
fergy flyer's Avatar
fergy flyer
Using different brands makes sense to me. I do the same, but switch with every 3rd or 4th tank. I have a Mobil, Sunoco, Shell and BP that I switch between. Also pure Techron once every time I change the oil.
Old Nov 5, 2005 | 08:49 PM
trends2000's Avatar
trends2000
had not considered using 87 in any of the vettes that i've had. everyone - i thought- used 93 octane (where available). with the c6, i'm averaging 22.2 since i got the car 3 months ago c6 w/a4 and g90) on the road, i get 28.5 usually at 75- 80 mph with the occasional sprint to 100. mileage is slightly less than my c5 but fine by me. agree with cost of 93 over 15k miles - have no desire to chance "rattling".
Old Nov 6, 2005 | 08:22 AM
SHOOTER 49's Avatar
SHOOTER 49
93 always.
Old Nov 6, 2005 | 12:04 PM
Vette_DD's Avatar
Vette_DD
93 octane BP/Amoco. Why try to save $1 or $2 on a fill-up for a $50K vehicle that's getting 23 mpg on premium?
Old Nov 6, 2005 | 12:09 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
93 Chevron
Old Nov 6, 2005 | 01:05 PM
vertC6's Avatar
vertC6
Reguardless of what car you are driving, with whatever engine, when you have a high performance engine with damm near 11:1 compression, and you get out and push it on at hot summer afternoon with 87 octane you are asking for trouble. You can't run 93 on anything over 12:1, so why would you risk runing 87 at 11:1. And if you do any addition upgrades, specially a s/c or turbo. KABOOM!!
Old Nov 6, 2005 | 02:39 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My understanding is that the engine system is dsigned so it doesn't need to pull timing under most conditions, if using Premium gas.
If using Regular, it will need to pull timing frequently. Which means I'm depending on the knock sensors and timing retard to save my engine from damage. Not the way i like to do it.
Old Nov 6, 2005 | 08:13 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Old Nov 7, 2005 | 02:30 AM
  #33
Daytona Sunset 2k5's Avatar
Daytona Sunset 2k5
St. Jude Donor '07
i only use 91...just preference i suppose
Old Nov 7, 2005 | 06:09 AM
  #34
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
where are you getting 98 oct
Old Nov 7, 2005 | 08:37 AM
  #35
6 speed Sid's Avatar
6 speed Sid
Back to the original post-- unless the salesperson is a Corvette enthusiast or specialist, I would take my advise from the folks here on the forum.
Old Nov 7, 2005 | 06:31 PM
  #36
c5 devil's Avatar
c5 devil
Default middle-east
Well i have moved from texas to qatar ( near saudi arabia )
And over here they have 98 and 95 octane........and i use 98
And dam does the car move
Old Nov 7, 2005 | 07:56 PM
  #37
jdwk's Avatar
jdwk
In Arizona all we have is 91, but I found a nearby gas station that has 101 at $6 a gallon.
My car has been very slow at the drag strip compared to other cars on this forum, so I thought it might be in low octane mode.
I put two gallons of 101 and two gallons of 91 in on an empty tank and headed to the track. It made no significant difference in trap speed.
The other two C6 there that night weren't doing any better and one filled up with 101.
Next time I will reset the PCM by pulling the fuses. That should make sure I come out of the low octane tables.
As for 91 or 87, I guess if 91 puts me in low octane mode, then going to 87 wouldn't make any difference. However, we are talking about $2.80 vs $3.00 so why not pay the extra twenty cents.
That's the amazing thing about gas, even though prices have doubled, the grades are still separated by ten cents.
To What octane do you guys use?
Old Nov 8, 2005 | 08:41 AM
  #38
StrayDog's Avatar
StrayDog
question what do you pay a gallon ????????
Old Nov 8, 2005 | 12:23 PM
  #39
Pipes's Avatar
Pipes
Thanks! I was wondering what effect Cali's 91 octane had, it's good to hear about your experience.
I think I'll be trying 87 octane for a spell, just to see if I can detect a change. I'll bet my ride has been stuck in the low octane table for most of its life.
Old Nov 8, 2005 | 01:28 PM
  #40
quickride's Avatar
quickride
One thing to remember here in this discussion about octane rating is that the octane requirements for all of us varies with climate and temperatures as well as our personal driving habits. Those of us who live in areas where the temperatures are normally higher (80's and 90's) will require a higher octane rating, so Premuim fuel will be more of a requirement than for those of us whose temps are much lower.
Almost all of us can get by with lower octane ratings during the winter months. Perhap many of you have already noticed how the octane numbers come down during the winter months, at least that's what happens here in California. During the winter, our premium octane rating is 91 and during the summer months, they bump it up to 92 or maybe 93 if we're lucky.
