Tire Pressure Sensor Question
Old Nov 6, 2005 | 12:00 PM
SA HEAT's Avatar
SA HEAT
Default Tire Pressure Sensor Question
Does anyone know if there's supposed to be a loose O-ring that goes with the tire pressure sensors? I've read something on the Forum where someone mentioned an O-ring but all I see is the rubber grommet at the base of the valve stem. Thanks!
Old Nov 6, 2005 | 12:50 PM
jkonkle's Avatar
jkonkle
Go big or don't go...
The use of the term O-RING and rubber grommet are synonomous I believe. I've been in and out with these TPSs and the only thing I've ever seen is a rubber grommet/o-ring. It's not really o-ring as it is step'd as I recall.
JK
Old Nov 6, 2005 | 06:46 PM
SA HEAT's Avatar
SA HEAT
JK
Perfect. That's what I was looking for. Thank you. Another question.....Does the curve of the sensor go with the curve of the wheel?
To Tire Pressure Sensor Question
