center console squeaks
Old Nov 21, 2005 | 03:25 AM
mach5's Avatar
mach5
Default center console squeaks
any one else have this prob? its sounds like plastic on platic and is very apparent while turning and u have ur weight against it
Old Nov 21, 2005 | 09:07 AM
PJinNJ's Avatar
PJinNJ
Default Easy fix
Open the console. Loosen the two screws at the front of inside compartment. Place weight on console and tighten the two screws while weighted. Squeeks will be gone. Happens mostly after a shifter install.
Old Nov 21, 2005 | 09:22 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Insert a piece of Velcro tape --- the soft part --- between any two pieces of plastic that rub and squeak. Its nylon, so it wears like iron and will permenantly stops the the squeak.
Old Nov 22, 2005 | 12:57 AM
mach5's Avatar
mach5
thanks guys
Old Nov 22, 2005 | 11:27 AM
jcgordon's Avatar
jcgordon
Default console noise
I'm having that problem now. I took it to the dealership for repairs. I never had the problem with my two C5 vettes (97 & 01). Very annoying on a 50+ grand automobile.
Old Nov 22, 2005 | 05:11 PM
jdwk's Avatar
jdwk
Yes, there is a quiet but very apparent creak coming from my dash just from normal road vibrations. I pushed all around on the trim to try to see where it was coming from and I was able to stop it by pressing down on the dash itself up by the big center vent.
It seems like it would take a lot of work to get some velcro underneath the dash itself. Much more so than just removing the trim.
Anyone else notice coming from this area? Will the dealer actually attempt to fix it if I take it in, and what are the odds they break something else in the process?
Old Nov 26, 2005 | 09:35 PM
DaVeed's Avatar
DaVeed
Check out my thread over in the C6 General forum
http://forums.corvetteforum.com/show...99&forum_id=74
After having the center console squeak / creak worry me to death for 7000 miles, it is now gone and I hope for a long time.
Old Nov 28, 2005 | 01:11 PM
TexasTechZ06's Avatar
TexasTechZ06
To center console squeaks
