Getting ready to install XM Roady2 in C6 coupe. I hope to install where ash tray is now. I seem to recall an install with pictures on this forum.
Any help would be appreciated!
Not sure if the Roady 2 will fit in ashtray.
Easy mount in console, close the door and it goes away !!!
Antenna mounted on dash to adhesive backed metal plate gives strong signal with no drop out. Wire run in fascia channel to console.
Ten minute install, no holes or disassembly of car. Remove without leaving a trace
