DBS Symptom
Old Nov 28, 2005 | 10:17 AM
fts's Avatar
fts
Default DBS Symptom
Over the past few months, I have noticed that if I have not started my C6 vert for three or more days that there is a noticable pause between the time that I depress the start button and the engine starts. Nevertheless, it does crank normally. However, once the engine does turn, a chime rings two or three times but there is no message on the DIC. After that, the engine starts normally every time unless I let the car sit for a few days again. Has anyone else had this happen? Do you think that it may be the prelude to a DBS?
Old Nov 28, 2005 | 11:20 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
It could be a bad battery failing to hold a charge. Might be time to try a new battery. Or have your battery tested.
If it still does it with the new battery, then I would look elsewhere. Is the car left in reverse?
JMO but this dead battery thing has a lot of people here unnecessarily spooked.
Old Nov 28, 2005 | 02:52 PM
mikeyc6's Avatar
mikeyc6
This post sounds similar.
Mike
Old Nov 28, 2005 | 08:10 PM
Hoonose's Avatar
Hoonose
There haven't been any preludes to DBS, and that's part of the problem. They occur so darn randomly. You're probably not going to get DBS from this.
I suspect you have a FOB recognition/interference problem, I get that rarely. Make sure your FOB is not around keys or any other items like your cellphone or even other FOBs.
Maybe for a few days, place your FOB somewhere clearly out in the open, like on the console before starting the car, and see if that helps.
Old Nov 28, 2005 | 08:12 PM
Hoonose's Avatar
Hoonose
Doesn't sound like a dying battery, but I would check the cables' connections.
To DBS Symptom
