Magnetic Drain Plugs
Old Nov 30, 2005 | 09:32 AM
vetdude's Avatar
vetdude
Default Magnetic Drain Plugs
I have a new magnetic drain plug I never got to install on my C5. Does anyone know if the C5 drain plug is the same size as the C6? Tnanks in advance.
Old Nov 30, 2005 | 10:08 AM
Av8ter's Avatar
Av8ter
From what ive read, they are the same, but youre going to need 2 of them.
Old Nov 30, 2005 | 10:27 AM
Miaugi's Avatar
Miaugi
Why two?
Old Nov 30, 2005 | 10:42 AM
VET4LES's Avatar
VET4LES
Originally Posted by Miaugi
Why two?
I have being draning through one.
Old Nov 30, 2005 | 11:17 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Originally Posted by vetdude
I have a new magnetic drain plug I never got to install on my C5. Does anyone know if the C5 drain plug is the same size as the C6? Thanks in advance.
I have a C5 mag on my C6, have no idea on why someone stated you need 2 of them though...
remember to buy some of the rubber seals for the base of the plug. (if you change your own oil)...
Old Nov 30, 2005 | 06:24 PM
Av8ter's Avatar
Av8ter
OOOPPPSS, nevermind about needing 2 drain plugs, I thought i was in the C6 Z06 section, in which from what ive read somewhere in changing the oil, there are 2 plugs to pull to drain the oil, one from the pan and another to drain the reservoir.
Old Nov 30, 2005 | 07:59 PM
cbrf4i1's Avatar
cbrf4i1
where are you guys getting these plugs? my local dealer stated they don't have anything like that. thanks
Old Nov 30, 2005 | 08:36 PM
easyrider13's Avatar
easyrider13
I got mine from Beans along with some oil filters.
Old Nov 30, 2005 | 08:44 PM
nalto's Avatar
nalto
Where do you get the rubber seals?
Top Cat's Avatar
Top Cat
St. Jude Donor '06
it's a GM part as well as aftermarket. Ask your dealer to give you the one for the C5 if he can't find the C6.
Specialty stores like West Coast Corvettes sell them also.
Old Dec 1, 2005 | 08:10 AM
vetdude's Avatar
vetdude
Your dealer should have them. If not, they can order them.
To Magnetic Drain Plugs
