Soft clutch problems
Old Dec 1, 2005 | 07:38 PM
radstoy's Avatar
radstoy
Default Soft clutch problems
I have been bit*hing about the "no feel" clutch in the C6 since I got it. After seeing some comment about the clutch tending to "hang up" at WOT it accurred to me that on several occasions at or near redline my clutch felt unresponsive in terms of returning to the up position while it was near the floor. Has anyone else noticed this phenomenon or are aware of a TSB regarding the issue. In short, What to do? Help! :Thanx Rad.
Old Dec 1, 2005 | 08:12 PM
lytmup's Avatar
lytmup
You know, I had this EXACT same problem on my 2000 Camaro SS 6-speed and it was the result of a sh!tty clutch pressure plate from GM. It even happened on the C5's as well and supposedly, the Z06 clutches were suppose to fix it. I ended up fixing mine by putting in a Centreforce.
I now getting worried, because I have just ordered a 2006 6-speed Coupe. If this is a common problem AGAIN, I will not be a happy camper.
Old Dec 1, 2005 | 08:36 PM
zaccotner's Avatar
zaccotner
Remove the clutch spring, makes a huge difference
Old Dec 1, 2005 | 08:58 PM
Hoonose's Avatar
Hoonose
There is definitely a GM fix for this, bring it in. They have to check the internals and make updates if needed.
Before the update was out, I seemed to have fixed mine with a minor clutch arm mod and reduced its throw. The clutch also engages sooner, which I like.
http://forums.corvetteforum.com/phot...00/ppuser/6747
You might want to try it if you're fearful of bringing your car in. I did this almost a year ago and that problem has not come back.
Old Dec 2, 2005 | 09:40 AM
davidfarmer's Avatar
davidfarmer
there is a tsb for early cars, so go to the dealer. The early clutches did not have enough spring pressure, and at high rpm (over 6000) they can hang open.
Clutch Pedal Does Not Return to Up Position During Shifts at Hight Engine RPMs (Inspect Date Code and Replace Clutch Kit) #05-07-31-001A - (Aug 17, 2005)
Old Dec 2, 2005 | 03:42 PM
stinky's Avatar
stinky
Yup, removing the clutch pedal return spring from beneath the dash works wonders for the feel of the clutch.
Old Dec 2, 2005 | 05:00 PM
67435animal's Avatar
67435animal
Agree, I removed my clutch pedal spring and the clutch is much more positive. Asked the service guys at my dealership and they said the pedal spring servedf no useful purpose.
To Soft clutch problems
