Widest Tires
Old Dec 1, 2005 | 11:30 PM
C6V3tt3's Avatar
C6V3tt3
Default Widest Tires
I just bout CCW 505a rims(19x12 rear;18x8.5 front). I have from before BFG's KDW2 (original sizes). I think there pretty good and would like to get the same again, but the widest i can get them befor they rub anywhere. Does anyone know whats the widest i can get?
Old Dec 2, 2005 | 12:54 AM
Jagcvette's Avatar
Jagcvette
Sorry buddy, but your not getting 19 x 12 from CCW, they only make 19 x 11. I was told that their 19 x 11.5 don't fit the corvette but I want to double check that (John is out until Monday). I am planning on purchasing the same wheels so I am very experienced in this area, or should I say frustrated. If you go with the 19 x 11, John recommends the non-runflat PS2s in 305/30 19s. They are a good fit for that size wheel and handle much better than run flats. You can also go with the Goodyear supercar run flats that come standard on the Z06, 325/30 x 19 but that is pushing the limits of wheel/tire ratio and you will have slight tire bulge (other forum members have posted pics and are happy with their combination). The Z06 wheel is 19 x 12 and handles the 325 just fine. Between the run flats and tire bulge with a 19 x 11, you won't get as good traction with the 325's as you would with the 305s. Hope this helps, feel free to give John a call on Monday, he's out at a car show until then. Jeff
Old Dec 2, 2005 | 04:32 PM
aaaaa's Avatar
aaaaa
they only make 19 x 11. I was told that their 19 x 11.5 ...
Which is it?
Aside from that-good advise.
Old Dec 2, 2005 | 04:38 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
http://forums.corvetteforum.com/show...19&forum_id=74
Old Dec 2, 2005 | 05:10 PM
Lusky's Avatar
Lusky
Here are mine, got them Wednesday.
Rear is 19 x 11 w/ 325/30 F1 SC EMT's
http://forums.corvetteforum.com/show...02&forum_id=74
Lusky
To Widest Tires
