Need technical info. please
Old Dec 2, 2005 | 12:49 AM
jjas's Avatar
jjas
Default Need technical info. please
I need to remove the tail light, running lights, third brake light and running light lense to get them blacked out. Will someone tell me how to remove these lights? Thanks in advance.
Old Dec 2, 2005 | 01:02 AM
DealerTech's Avatar
DealerTech
image file at this hyperlink
http://img521.imageshack.us/my.php?image=14863940gc.gif
Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in Cautions and Notices.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal Lamp Assembly Replacement - Rear
1
Screw, Turn Signal - Rear
Tighten 2 N·m (18 lb in)
2
Lamp, Turn Signal - Rear
Tip Twist the bulb socket and pull inward to replace the bulb.
Stop Lamp Assembly Replacement
3
Screw, Stop Lamp
4
Lamp Assembly, Stop Lamp
Side Marker Lamp Replacement - Rear
5
Lamp Assembly, Side Marker - Rear
Tip
• Remove the side rear compartment carpet for access.
• The lamp releases by pressing the tabs inward.
• Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement
6
Screws, License Lamp (Qty: 2)
7
Lamp, License Lamp
Tip
• Remove the rear fascia. Refer to Fascia, Lower Fascia, Absorber Replacement - Rear Bumper in Bumpers.
8
Screw, Backup Lamp (Qty: 2)
9
Lamp, Backup Lamp
Tip
• Remove the rear lower fascia. Refer to Fascia, Lower Fascia, Absorber Replacement - Rear Bumper in Bumpers.
Center High Mount Stop Lamp Replacement
10
Nuts, Center High Mount Lamp (Qty: 4)
Tighten 4 N·m (36 lb in)
11
Screw, Center High Mount Stop Lamp (Qty: 2)
12
Lamp, Center High Mount Stop Lamp
Tip
13
Bezel, Center High Mount Stop Lamp
Old Dec 2, 2005 | 09:42 AM
davidfarmer's Avatar
davidfarmer
just uncrew the single screw in each of the brake lights, THEN reach in through the center brake lights and remove the 10mm nuts holding the 3rd brake light to the bumper. There are 4 of them, two are accessible from each side. You will need a small 10mm wrench or socket
Sometimes the 3rd brake light seems stuck to the bumper, but once the bolts are out, it should come up with a little effort. I think some were attached while the paint was still a little wet.
Dave
To Need technical info. please
