C6 AH/TC Warning: please read
Problem was, AH never came on. No message, nothing.
Last night, I decided to do a test. There is a large parking lot in my town with no light posts, blocks etc. Part of it is flat, the rest ondulating with dust etc on it. Took the car there and started running tight laps and figure 8s with AH/TC fully on.
Folks, with the system 100% "on", I was able to powerslide at will, spin the car multiple times (imagine a drifting contest), and generally totally lose control. Speeds were up to 30 mph or so and some of the spins were massive and would have caused one to hit something and total the car had they occurred on the street. During this time, the AH/TC NEVER came on. No warnings, no nothing. Zip. Just as if it is not there. I repeated with the system turned off, then with Comp. mode...no difference.
I want to stress that I could induce a power slide at will, with absolutely zero intervention from the car. I have had two C5s and took both to this same location. Neither one of them would allow ANY of this to occur with AH/TC on. Any attempt to powerslide with the gas and the engine would cut back. Oversteer the car into a corner and the car would straighten it out.
I don't care for myself: I compete a Formula Mazda and I am now into shifter Karts, so I have plenty of driving experience and I have drifted, power steered, and spun cars a-plenty. What saved me the other day, is that I have plenty of experience correcting my mistakes. No big deal for me. However, my wife, who is not experienced in this way, also drives this car. With prior Corvettes, I always felt OK with her driving a powerful car, because I knew the systems were there to help her if she got into trouble.
I am sorry to say I have lost that faith completely with the C6. I am not sure if there is a malfunction with the system (I have seen AH coming on occasionally on some of my fast mountain drives, so I know it does "work"), or whether it only intervenes at high speeds.
What I do know is that many others have reported similar incidents, with three others (including a new Z06 owner) not so lucky and crashing their cars. And make no mistake: this IS a problem. I know this because I know what a properly functioning system does (the C5's).
So, C6 owners, DO NOT expect the system to save your butt in these cars. Expect it not to be there when you need it. For my part, I bought a car with a stability control system, which I expect to work just like the one in the prior model, and I will be taking this all the way up the line until I get answers. Not cool, GM
I might add that I have had similar indications lately - there's been some messy weather around, and I've spun the rear tires pretty well a couple of times without TC doing anything. One of those I definitely had to compensate to avoid banging the rear end into a mailbox. I had a Z28 with TC that would stop the rear tires spinning very quickly - too much so, for my taste. But the main thing is needing to know what's going to happen before it does!
And yes, the car is definitely going to the dealer, as step one. I will make sure this gets to the NHSTA, one way or another.
I just open tracked my new C6 Z06 for the first time this weekend, and never had the AH kick in either. I did activate the traction control while accelerating hard in a straight line over bumpy pavement, though.
I thought it didn't intervene because I was such a smooth driver. ;-)
Now I need to go repeat your experiment. I know the C5's setup was much more intrusive.
I don't want to minimize your situation, you should get it checked out right away. But your post is a pretty gross generalization. Ok, your car has an issue and I at least appreciate you letting us know about it. But there's over 40,000 C6 owners right now. If you've seen 3 or 4 people having problems similar to yours, or even 20 or 50, does that qualify as "a lot?"
As for what speed it comes on...mine has intervened when turning a 90 degree corner doing 10 to 15 mph. It seems to work at any speed.
coincided with a lower laptime. On my C6, it is just AWOL, period.
To others:
Yes, it happened on my car.
No, that is not normal, which = malfunction, so...
Yes, it is going to the dealer.
That applies to me. What you should be asking yourself after reading this is: "Am I sure my car's TC/AH is functioning properly and, if in doubt, should I have the dealer check it out". You can be sure it is NOT operating properly, if it does not halt a powerslide.
Disclaimer: I am not advocating driving like an idiot on public roads just to see if "it works". If you have not been to driving school and have no competitive driving experience, then please do not test it and just take it to the dealer. The others will know what to do.
The thing is, how is the tech at the service department supposed to work on that? What the heck do they know about when AH should kick in, and how would they test it? Maybe you've got a great tech, but I know that if I went to my dealer, they would see no codes, and say that it's fine. Especially since it does come on at some point.
Let us know what happens.
Went to the gas station and after my fill up, I started the car and a warning message popped up:
something like "service active handing or service traction control or traction control inactive...."
I pushed the buttons and have not seen the warning since.
I must say, I've never felt it intervene, ever.....
Howard
Just my thoughts.
I've owned some of the fastest cars around, but.....
It is nice knowing that if something unexpected happens at a time when those controls are on, it is nice to have a little extra help.
I am definitely not Mario Andretti, but I did pilot a stock Viper except for air filters and Kumho radials to a 11.6@120+ 1/4 mile time, not many people have done that.
The Viper had no traction aids, my 03 Cobra has them, 1/2 the time I have them off (in case I have ot beat some Vette
), and in my Vette I usually use Competion Driving mode for that little margin of extra safety - If it works
Howard
Howard
but I could not tell you of a time when I thought it shoud have and it did not work.
