Need Help ASAP
Old Dec 9, 2005 | 11:19 AM
Lusky's Avatar
Lusky
Default Need Help ASAP
I was in the process of installing my Vararam. I was cutting the fan shroud while laying in the engine compartment. I was cleaning up the cuts with a knife when I slipped forward & the nife sliced through the coil. I guess this would be for the air conditioning system? I can hear the air pressure coming out.
I messed up bad.....how do I remove the fan shroud? Can I remove this item & have it repaired?
thanks in advance,
Lusky
Old Dec 9, 2005 | 11:57 AM
VET4LES's Avatar
VET4LES
Take it to an A/C shop. The coil can be repaired or replaced if it is not to much money. The system then need's to be evacuated and recharged. You can do it you self if you have a vacuum pump and then add the correct amount of 134. Good luck.
Old Dec 9, 2005 | 01:42 PM
Lusky's Avatar
Lusky
I'll go take a drive an check with the local a/c shops
Well, at least I got the Vararam installed
Lusky
Old Dec 9, 2005 | 02:48 PM
lovecars's Avatar
lovecars
thanks in advance,
Lusky
Let a semi professional do it (Chevy dealer) they have the right tools. And it guaranteed if the jobs is not right...
Old Dec 9, 2005 | 02:58 PM
SC TROJAN GRAD's Avatar
SC TROJAN GRAD
Old Dec 9, 2005 | 03:20 PM
Lusky's Avatar
Lusky
this is exactly what i decided to do.
thanks
Lusky
To Need Help ASAP
