what exactly 'tuning' means?
In the old days a/f was done by turning a screw on the carb, delaying secondaries, changing jets....on the C6 you cant even change the idle for a different cam without reprogramming. Idle isnt just the rpm level...its timing at idle, an Idle air motor allows more or less air in while not under load and there is rate of rpm decrease after you rev.
Timing....you used to turn a distributor for the entire timing range to advance or retard but you could also change counter weights and their springs to change the rate of advance.
Now you map the entire RPM band by load and add where you want and retard where you want.
A/F is measured by O2 sensors in closed loop operation to maintain stoic and when it is lean the car increases the injector fuel delivery and if you are rich, the opposite. At wide open throttle it takes measurements from your previous driving to make the car run 13:1 and the O2's are out of the loop.
When you make changes to the car those changes throw off the car's preset tables that it iuses to estimate proper fueling and timing and then runs wrong and gives you check engine lights since sensors like the manifold absolute pressure doesnt agree with predicted airflow from the other sensor's readings.
Changing exhaust backpressure for instance clears out the cylinders more efficiently causing less remaining hot spent gasses and allows cooler air and fuel to take its place faster...this would cause a lean condition since the air going in is more dense.....lean long term fuel trends = richer WOT operation. Same thing with a more efficient intake manifold...more air gets in than predicted and the car cant compensate unless you tune it to your specific mods.
Kikis has all sorts of american cars in his garage and modifies anything u can imagine, he had a twin turbo srt10 dodge ram, a supercharged new mustang, couple of oldies, a C4 2 C5s and my C6 around a month ago in his garage... ull find anything from ferraris to trucks there... search him out on the net.
His garage is in north london and his number is +44 207 281 8018, ask 4 Kikis. He is a Cypriot too that has been in London for the past 30 years or something
I have no access to tuners. If I just go with a cat back (Corsa Sports) and CAI will the car need to be tuned? Thanks.
Thanks.
Thanks.
Joe
The computerized systems give you much more control than you had in the old days. You just have to learn how to use different tools. Instead of turning a screwdriver, changing jets, adjusting a choke, recurving a distributor, etc, you simply need to learn how to enter numbers into a laptop. Much easier, much quicker, much less trial and error.
