Tire Pressures
Old Dec 11, 2005 | 12:19 PM
scooter32's Avatar
scooter32
Default Tire Pressures
What should the tire pressures be cold? Mine are 23 front/ 24 Rear when I start the car. They go up 1 pound after about 2 miles of driving and the tire pressure light goes off.
Old Dec 11, 2005 | 12:24 PM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
30 psi cold works for me. 25,000 miles on original set of tires and still have good tread
Old Dec 11, 2005 | 02:27 PM
LS1LT1's Avatar
LS1LT1
That's way too low, you're giving up handling/breaking performance, tire wear and fuel economy...I like 33-34 psi, 30 psi is the minimum for street use IMO.
Old Dec 11, 2005 | 02:46 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Thirty when the tires are cold. Tire Presure light will not come on if tires are up to right presure. Normal driving will bring them up 2-3 lbs. in a couple miles of driving
Old Dec 11, 2005 | 10:06 PM
Lebowski's Avatar
Lebowski
I agree 23-24 sounds way to low. FYI, in most (probably all) cars, there's a sticker in the drivers side door well that has the OEM recommended tire pressure. I've heard that manufacturers typically low ball it by a few psi because they favor a smooth ride over better handling, so if you care about handling more than ride you can probably go several PSI over the OEM recommended pressure.
Old Dec 11, 2005 | 10:11 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Dec 11, 2005 | 10:24 PM
cmb13's Avatar
cmb13
I'm running 32 all around.
Old Dec 11, 2005 | 10:29 PM
jschindler's Avatar
jschindler
30 all around (cold).
Old Dec 11, 2005 | 11:20 PM
VET4LES's Avatar
VET4LES
30 pounds here.
Old Dec 12, 2005 | 12:12 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Was running 30 lbs all around as stated on the door sticker; recently went to 32 & handling seems to be somewhat better.
Old Dec 12, 2005 | 12:21 PM
MitchAlsup's Avatar
MitchAlsup
30 PSI cold is a low as you should even consider, likewise 35 PSI cold is as high as you should consider.
I happen to like 32 PSI as it makes the car a touch quicker in response without stepping over the line into harshness (Z51).
Old Dec 12, 2005 | 12:28 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
And mine are filled with nitrogen.
Old Dec 12, 2005 | 04:17 PM
ohfiver's Avatar
ohfiver
31 for me and ride and handling seem fine.
Old Dec 12, 2005 | 04:47 PM
jdwk's Avatar
jdwk
I'm constantly taking out air and putting it back in for the drag strip.
My fronts are at 34 cold, rears 32. I drop the rears to 26 for the strip. I don't notice any difference in handling when I do though.
Old Dec 12, 2005 | 05:28 PM
SpinMonster's Avatar
SpinMonster
Aircraft guy? I have mine stored in my families' hangar and never thought of that. Thanks
Old Dec 13, 2005 | 03:55 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Old Dec 13, 2005 | 04:28 AM
jkonkle's Avatar
jkonkle
Go big or don't go...
Too low - as we may forget; outside temperature affects tire-cold pressure.
I always watch the temp here in CenTex cause at morning it can be 50degrees; so you air up. However, by noon the ground and outside temperature rise swiftly. So you can be up to 35/36 pretty quick.
Highest I've seen was 38 (actual) - that was back in Sept when were having 105 days and I aired up the tire due to a slow leak. I wasn't hot-rodding it though.
30psi is always a good start; carry a good pressure gauge!
JK
To Tire Pressures
Old Dec 13, 2005 | 09:35 PM
6 speed Sid's Avatar
6 speed Sid
31 cold works for me.
Old Dec 14, 2005 | 06:33 PM
sjreeh's Avatar
sjreeh
If you are serious, please explain why.
Old Dec 14, 2005 | 07:18 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
32 is good unless you want a little softer ride, then go for 30.
