Underdrive Pulleys
Thanks Yall.
No lights dimming, no start issues, the car runs at 14.2 volts, and you wont know it is there. A/C works fine too. Shop around and get a good deal....tbyrne 10% off the listed price if you order online. One thing: for C6 users; the C5 ac belt is one inch too long. You need a 40 inch not 41 as tbyrne had originally shipped me.
If anyone says this mod isn't a good one or it will give you problems then they don't have it on their car-- and shouldn't be giving you advice. I've noted those guys usually say they had it on their z28 back in 1978 and it made their lights dim. Dated opinion. Different car/different results.
I agree, doing the cam at the same time is prudent, if you believe in just doing he cam to begin with. Which is a pretty big decision as your warrranty is pretty much history and without the heads the gains aren't so great, and if you decide to do it all its a big financial expediture even compared to just the labor to put pulley's in.
Ahhh, decisions decisions
Thanks Yall.
Remove the coil packs, valve covers, plug wires
Remove the valvetrain; rockers and pushrods
drain all fluids
Remove the air cleaner assembly, air bridge, Maf
remove the TB (just for more room)
remove the water pump
Remove the timing chain cover
Remove the fan
Remover the radiator, its cover, all hoses
remove the oil pump unless you trust that the chain wont come off
Remove cam gear w/o dropping the chain
Remove the cam without destroying the AC lines
Tuning for a cam is a must...add 500 there
The stock valve springs wont work with any new cam worth installing
15-20 hours for a cam change if you're fast
Your mechanic is an idiot. Even if you pay 210 (70 per hour) to install a pulley it is under 500 for 9-10 hp and that is 50 per hp....right in line with any good mod. Find a good mechanic.
drain all fluids
Remove the fan
Thanks for the instructions. This is funny because I'm mechanically inclined in working on motorcycles but not cars. You may had missed my point. It was a suggestion only to install the cam along with the underdrive pulley. It would save me on labor cost if I get both done. That's all.
Another question, the manual says to mark the pulley/balancer
before removal so you can reinstall in same spot. How do you do this when installing a different pulley/balancer. One vendor told me to install it in any position.
I've since long sold that 300ZX and am looking at a Corvette in the near future. Always enjoy reading the forums here!
Anyway, its a great mod even staying with the stock cam.
A lot of track guys run an electric water pump so they can keep the pump going with the car off still cooling.
I'd like to some dyno charts to see where in the RPM range the gain is achieved.
Also, note that basically with a smaller drive pulley you are spinning all the pulleys slower, which I think everyone knows, but let's look at the effects on some of the systems, in all cases I would think that GM tries to spin them at the min speed to save on fuel economy.
power steering:
spinning this pully slower should have positive effect in power, but may result in increased power steering effort at idle. It may not be apparent at first, but may appear over time. Basically the pressure of the flud will be less and over time effort may increase.
water pump:
cooling flow is reduced, this should also have a positive effect in power, but may result in over heating. The flow rate will be less so overheating is a possibility;however, since you have a gauge to monitor this, it would be the least of my concern.
a/c:
could reduce a/c performance at idle, but you can always turn of a/c, no real gains here....
alternator:
may or may not get any benefit, since the alternator is regulated, it may increase the torque when the speed is lower, resulting in same power requirement since torque*RPM=Power. If you measure the output of the alternator before and after and it is the same, you got no benefit from alternator.
reduced mass:
win win situation
balanced crankshaft:
could be worrysome for the long term durability of engine, this will probaby vary in a case by case basis depending on how well balance the end crankshaft/pully combo is. You may think it ok because of a lack of vibration/noise, but the engine is pretty isolated and holding the crank tight, the stresses around the crankshaft bearings would be increased.
power steering:
water pump:
a/c:
alternator:
reduced mass:
win win situation
Like I said, the only people who knock this mod are the people that don't have it. Here we have a man that went through all that opinion and as previously stated...NONE of those theories hold true in practice. The car runs better, same running temp, same power steering assist, same voltage, same freezing ac, and no vibration since the engine is internally balanced with a zero balanced pulley from the factory.
HP can be verified at www.ls1howto.com 9-rwhp
Sorry everyone doesn't reinvent the wheel everytime a doubting thomas comes along and needs proof. Everyone that has it, has the gain and none of the downsides you theorized.
power steering:
50 bucks per HP isnt worth it?...thats 25 per HP if you install it yourself. Thats is as good as it gets on the 'worth it' scale.
water pump:
a/c:
alternator:
reduced mass:
win win situation
