I'm looking for torque settings for the C6 swaybar endlinks and bushing clamps bolts... and since you're looking those up , could you tell me if the caliper/caliper bracket bolt is torqued to 125 ft/lbs(!?!?!?)
manual says...
sway bar end links: 53 lb-ft
sway bar insulator clamp bolt: 49 lb-ft
sway bar insulator clamp nut: 70 lb-ft
lower control arm rear cam nut: 70 lb-ft
Aren't the last 2 the same thing? This is what the torque list says, and the instructions for sway bar installation just say "Install the stabilizer shaft insulator clamps to the stabilizer shaft and the crossmember." Then to tighten to above specs. Maybe it makes sence when you're looking at it.
As for the brakes, caliper guide pin bolts: 23 lb-ft
