Stock LS2 Cam Overlap
Old Dec 18, 2005 | 01:12 PM
VetteNo2's Avatar
VetteNo2
Default Stock LS2 Cam Overlap
What is the stock LS2 cam overlap?
Old Dec 18, 2005 | 10:01 PM
davidfarmer's Avatar
davidfarmer
it is the same as the 01 LS6 cam, so look here, halfway down
http://www.idavette.net/hib/02ls6/page2.htm
Old Dec 18, 2005 | 10:02 PM
davidfarmer
Old Dec 19, 2005 | 06:23 PM
VetteNo2's Avatar
VetteNo2
Thanks!
Old Apr 13, 2020 | 06:11 AM
3R1$C's Avatar
3R1$C
Unfortunately, this link is no longer working. What is the overlap?
Old Apr 13, 2020 | 12:07 PM
old motorhead's Avatar
old motorhead
Overlap is calculated...Average duration (intake + exhaust duration divided by 2) minus LSA (lobe separation angle) times two. I'm sure the LS2 cam has major negative overlap. Any cam GM put in a production automobile in the last 20 years has negative overlap. Not knowing the LS2 cam specs, I can't calculate it for you.
Old Apr 13, 2020 | 12:21 PM
M419's Avatar
M419
-23.5 degrees.
Old Apr 13, 2020 | 12:40 PM
3R1$C's Avatar
3R1$C
Thanks man. What is the largest camshaft you guys have over there that makes it through the SMOG regulations in California / 50-state regulations?
I am in Germany and we have the same emissions craziness over here.
Old Apr 13, 2020 | 02:37 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Overlap Calculator:
Just enter the cam's intake and exhaust duration and LSA ... it will give you the overlap
http://www.wallaceracing.com/overlap-calc.php
Old Apr 13, 2020 | 03:09 PM
M419's Avatar
M419
I honestly don't know of a cam that will pass smog, you're going to have to get in touch with the likes of BTR, TSP, Pat G on this forum and other people/places that know quite a bit about cams. If I had to guess, every factory cam will pass smog including the LS9 cam but the gains/$ really aren't worth it there. You could go with a supercharger setup that will pass smog, but then you're looking at roughly 3-5 thousand dollars more for a much more substantial gain (think 100-200hp vs a cam that'll net 20-30hp in your instance) and never have to worry about passing smog.
Old Apr 13, 2020 | 04:00 PM
3R1$C's Avatar
3R1$C
Thanks for the reply!
Old Apr 13, 2020 | 11:54 PM
BonePhoenIX's Avatar
BonePhoenIX
Dirty Smog is always an option. You'll pay more.
Old Apr 14, 2020 | 01:46 PM
3R1$C's Avatar
3R1$C
I'm over here in Germany and I would need to make damn sure this cam would pass emissions. Imagine spending all this money and effort only to hear from the authorities over here that it cannot pass. What cam options do we have for blown motors (positive displacement superchargers) if we want to fulfill SMOG / California emissions regs?
Old Apr 14, 2020 | 02:50 PM
Turbo6TA's Avatar
Turbo6TA
Leave the stock cam in it ....
Or if you are intent on changing it since you will be supercharged, look for a cam with an LSA around 117 degrees (no less than 117). And if you want the valve springs to last a long time, keep the lift below .600"
Here are the cam specs for the LS9:
Dur: 211°/ 230°
Lift: .562” / .562”
LSA: 122°
ICL: 122°
Overlap: -23.5°
To Stock LS2 Cam Overlap
