C6 with Onstar
Old Dec 22, 2005 | 08:15 AM
03ZOHSX's Avatar
03ZOHSX
Default C6 with Onstar
I'm considering getting an 06 C6. I was reading an article in Chevy HighPerformance that before a Jet programmer can be downloaded that the OnStar fuse must be taken out. As they put it, "so the good samaritans don't find out". Does anyone know what the ramifications of doing this without taking out the fuse would be? Or, after downloading the jet programmer can you put the fuse back in and if so do the OnStar police know you've changed the computer?
JS
Old Dec 22, 2005 | 02:20 PM
shopdog's Avatar
shopdog
JS
Typical car rag misinformation. When reflashing the ECM, it is a good practice to remove the radio fuse, and if so equipped, the OnStar fuse. That's because they all operate over the Class II bus, and you don't want any contention for that bus while you're doing a reflash. It is possible to corrupt the reflash if there is other activity on the bus while the programming is in progress. It is like the admonition to always shut your windows computer down properly. 9 times out of 10 just pulling the plug won't hurt anything, but that 10th time it could corrupt the file system. Same idea here.
