MAGGIE or PROCHARGER
Old Dec 25, 2005 | 12:45 AM
701's Avatar
701
Default MAGGIE or PROCHARGER
Has anyone had a bad exp. with either????? I have heard that the mag creates alot of heat ?? The car will be used 99% on street. Maybe a drag now and then. My BIGGEST concern is RELIABILITY and LONGGEVITY. The hood issue isnt a worry of mine. I sold my 600hp cobra and I want something more streetable. I'll be getting a 06' coupe...Plus its gotta be faster than my neighbors 04 viper.....
thanks
Old Dec 25, 2005 | 12:42 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I prefer an ECS Paxton Novi kit but I might be a bit bias
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Dec 25, 2005 | 02:11 PM
SpinMonster's Avatar
SpinMonster
Chris, how did you go about tapping the engine oil for the S/C...the oil pan or the dip stick?
Does the intercooler require relcating or modifying the radiator mount?
Old Dec 25, 2005 | 05:59 PM
Mr.Big's Avatar
Mr.Big
Love my ATI P1SC kit, however 21st Century Muscle Cars changed a ton of stuff in the kit to meet my needs... Can't argue with 620rwhp and 518rwtq at 5.5 psi...that's = 713hp at the crank
Jeremy
Old Dec 25, 2005 | 06:13 PM
timd38's Avatar
timd38
Me too, I live in Novi.
Merry Christmas.
Old Dec 25, 2005 | 09:54 PM
701's Avatar
701
thanks 4 the info guys. But does anyone have any answers with exp. on these to types of s/c.. thanks
Old Dec 26, 2005 | 11:35 AM
701's Avatar
701
Thanks, its not that far from where i live in the rockford area. I,ll have to talk to your buddy in a couple of months........
Old Dec 26, 2005 | 08:02 PM
Mr.Big's Avatar
Mr.Big
What do you want to know about the ATI Procharger kit?
Jeremy
Old Dec 26, 2005 | 09:10 PM
701's Avatar
701
I'm looking for pros and cons on each type. longgevity and reliability are my main concern.
Old Dec 26, 2005 | 10:14 PM
corvetterich's Avatar
corvetterich
Hey any experts out there, I'am looking for the same answers as 701,
I also have a RX7, and the best system for this car is a Turbo. I'am very familar with the Turbos...
I really need to know from any experts on this C6 car,
1.Does the Mag Charger produce more heat than the ATI Charger.
2.Does the Mag Charger produce more Low end power than the ATI.
3.Which system is easier to install and work on...
4.Which system is less problems less maintainence..
5.which system produces more power through the entire rpm range...
I'am not worried about pricing or that with the Mag , we need a new hood, I was going to replace it anyways...
Old Dec 26, 2005 | 10:34 PM
701's Avatar
701
from what i understand so far is the maggie is a better low end producer and the pro/c is a bigger hp producer on the top. Someone told me that the maggie creates ALOT of heat which aint good..But the person who told me that was a pc dealer. The mag def. is a good looking unit. Like i said our main goal is reliability and longgevity. Is one really better than the other.........................Craig
Old Dec 27, 2005 | 01:12 AM
mdhmi's Avatar
mdhmi
The MagnaCharger is far closer to OEM reliability than any of the centrifugal kit on the market.
Mark
Old Dec 27, 2005 | 08:59 AM
701's Avatar
701
Does the mag. create alot more heat than the pro/c. and if yes what does it harm...
Old Dec 27, 2005 | 03:37 PM
pDz's Avatar
pDz
i've had a good experience with a centrifugal blower in the past. although, it was a smaller displacement engine so it would have been a better solution there to have a posi-displacment blower (like the maggie).
in the end, the two major problems will be ECU programming (i mean fuel/air at every single data point in the curve, not just for WOT) and heat soak.
naturally aspirated cars are not setup from the factory to deal with the heat that forced induction brings so you have to be thoughtful in your approach to deal with the added heat under the hood.
i'd also like to hear why people pursue posi-blowers for these v8s because it isn't as though they suffer from a lack of low end. what you seek is power, which would seem to be solved by turbocharging or centrifugal blowers. positive displacement blowers place a constant strain on the engine because boost is always there (not to mention potentially higher levels of drag on the engine) whereas turbos or the centrifugal blowers max out the boost at higher rpms so the peak psi and effective compression on the engine is lower meaning less wear and tear.
Old Dec 28, 2005 | 12:11 AM
701's Avatar
701
Thanks for the input. Very informative. Some of these cam and head packages look to be great performers also, thats got to be more reliable than a blower......
Old Dec 28, 2005 | 12:21 AM
hennytime's Avatar
hennytime
in terms of power, ive seen nothing special about the maggie on the gto or corvettes, but havent heard anything negative about them either.
Old Dec 28, 2005 | 12:39 AM
701's Avatar
701
I'm looking to be reliable and be able to run w/a viper. If it gives me half the thrill my BB cobra did I'll be happy. I got sick of tinkering with my cobra all the time and it wasnt a car I would want to drive for more than an hour or so.
To MAGGIE or PROCHARGER
Old Jan 4, 2006 | 01:23 PM
race9899's Avatar
race9899
I have done some work on a Procharger 06 Vette and was very impressed with install and performance.
They were doing the tune on it at Fastchip in Tulsa
Old Jan 5, 2006 | 09:27 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
I'm planning on putting a supercharger on my C6. It's a convertible so it won't spend much time at the track (won't go with a roll bar). The motor spends most of it's time below 4000 RPMs so I want to feel the horsepower increase without having to go higher than that. For this reason I'll be using the Magnuson. If the car was going to spend more time at the track and in the higher RPM range, they I would be leaning more towards the ATI.
Old Jan 5, 2006 | 11:47 PM
NineBall's Avatar
NineBall
The Magna will give better low/mid rpm throttle response. It will feel like you have a 427ci stroker under the hood. They make full boost at around 2K rpm, and are fun on daily-drivers. The ProCharger will be quicker on the highway, and probably put down better peak hp numbers. Centrifugals take rpm to start making good power, they aren't "instant-on" like the roots/screw type blowers. The ProCharger *should* put down better times at the track, but you will feel the Magna's results more often, on a day-to-day basis.
I'm putting the Magna in mine, I had excellent results with the same setup on a 348ci LS6: www.ExtremeG.net
Tony
