Normal battery voltage...(after DBS)?
Old Dec 30, 2005 | 04:25 PM
blittle's Avatar
blittle
Default Normal battery voltage...(after DBS)?
Now that I've got my electrical system back up after the wonderful DBS episode ...........I'm watching the battery like a hawk.....with the car shut down it is currently reading 12.86 volts. What would a normal range be?
Old Dec 30, 2005 | 04:44 PM
Brett Hunter's Avatar
Brett Hunter
I can't remember how long the battery needs to stabilize before testing but the fully charged voltage is 12.7. I would recommend checking the voltage after the car has not been started for a couple of hours and make sure it is close to this voltage.
Old Dec 30, 2005 | 06:10 PM
MitchAlsup's Avatar
MitchAlsup
A fully charged battery -- hot of of the charger will be in the 13.8-14.0 V range.
After cooling overnight, this battery will stabilize at 13.2-13.5V
Old Dec 30, 2005 | 06:22 PM
C8-Vette's Avatar
C8-Vette
Originally Posted by Brett Hunter
I can't remember how long the battery needs to stablize before testing but the fully charged voltage is 12.7. I would recommend checking the voltage after the car has not been started for a couple of hours and make sure it is close to this voltage.
A fully charged battery is 12.75 Volts. However voltage can drop to 12 or slightly less and the car will still start. A lot depends on temperature.
Old Dec 30, 2005 | 07:01 PM
DANNOV's Avatar
DANNOV
During the winter my C6 (Z51 with manual trans) is usually inactive. When I went on a trip about 2 weeks ago, the voltage at the battery, read with a meter, was 12.8 volts. This was after shutdown and after a fairly long drive. After sitting unused for 2 weeks, the meter read 12.5 volts.
Old Dec 30, 2005 | 07:09 PM
haljensen's Avatar
haljensen
Depends on the age and condition of your digital multimeter and connections, should be 12.6V but 12.5 to 12.7 with no load (the light on the hood is a load) is correct.
Don't try to use the voltage meter in the car, it's reading alternator output not battery voltage.
Old Dec 30, 2005 | 07:41 PM
blittle's Avatar
blittle
Thanks guys.........sounds like I'm in the ballpark. I'm hoping to catch this thing in the process of losing power so that the dealer can get a read on what is doing the draw down but I'm sure I won't get that lucky! In any event I'm going to check it with the digital meter before bedtime and first thing in the morning for a couple of days
Old Dec 30, 2005 | 09:23 PM
Hoonose's Avatar
Hoonose
It would only be of benefit if you did this night and day at the dealership, because even if you did find something (and you already know that you won't), you have to get it to the dealer to be looked at. And starting the car negates everything.
Save your time and don't bother. Either live with it like I have (DBS times 3, but hasn't happened again for almost a year), or get a prioritystart module.
Old Dec 30, 2005 | 09:32 PM
blittle's Avatar
blittle
Any problems with the priortitystart install or complications with other electronics?
Old Dec 30, 2005 | 09:39 PM
Hoonose's Avatar
Hoonose
Sounds like it works fine. Do a search here on the forum for the particulars, as I never opted for it.
To Normal battery voltage...(after DBS)?
