Question about start button on C6 with auto?
Old Dec 31, 2005 | 08:24 AM
888usa's Avatar
888usa
Default Question about start button on C6 with auto?
Maybe i'm being stupid but just got my new C6 2005 auto, I just want to know if anyone knows will the car switch off if you are driving along & knock the start button by accident? I just thinking doing 70 mph & that happens you may end up in trouble!
I tried driving in my garage & switching the car off in drive which it did turn off with the car in drive! And to start again you have to put the car in park & press the brake but this was at zero mile an hour, So it may have a safety fitted to it does anybody know??
I'm in England so not to many of us have a C6 yet!
Old Dec 31, 2005 | 08:30 AM
nalto's Avatar
nalto
Wow, good question. I'd like to know the answere to that as well?
Old Dec 31, 2005 | 08:44 AM
SC TROJAN GRAD's Avatar
SC TROJAN GRAD
ttt
Old Dec 31, 2005 | 09:21 AM
Vette_DD's Avatar
Vette_DD
An AUTO tranny car should start with the gearshift in NEUTRAL or PARK, as long as you have your foot on the brake.
Old Dec 31, 2005 | 10:57 AM
ufso's Avatar
ufso
I have a A4 and hit it at about 50 mph...nothing happened, no sound, no nothing.
Old Dec 31, 2005 | 10:59 AM
CYA-Vett's Avatar
CYA-Vett
Maybe someone can test this on a dyno???
Old Dec 31, 2005 | 11:18 AM
888usa's Avatar
888usa
Dyno thats it! or abrave person to test it at 100 mph on a freeway!
Old Dec 31, 2005 | 11:55 AM
calemasters's Avatar
calemasters
Yes it will shut off while driving if you press the bottom of the rocker switch. To restart, you have to shift into Neutral or Park. I do not recommend Park if you are rolling.
Old Dec 31, 2005 | 11:57 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
The motor just stops, push the go button and it starts back up without engaging the starter, kind of eerie. Tried this since there were reports that the engine would shut off if you accidentely hit the button. Sure enough, it does.
Old Jan 1, 2006 | 01:29 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Damn you're a brave sole. But, I do thank you. You just saved me from having to leave the warmth and comfort of my den to go try it for myself.
Old Jan 1, 2006 | 09:10 AM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
When my POS was going through all kinds of intermittent electrical gremlins, I tried it in hopes that things would work when I restarted.
I made sure I was on a very straight stretch of road, put it in neutral, hit the stop button, I thought I felt column lock but I didn't wait long enough to be sure, hit the start button, and then put it back in D. When it was turned off, I may have felt increased steering resistance from no power steering assist instead of column lock.
To Question about start button on C6 with auto?
