C6 Shift Light Install
Old Jan 24, 2006 | 05:29 PM
ShockerRacing's Avatar
ShockerRacing
Just thought I would point out that I did update where to ground the shift light!
Old Nov 8, 2014 | 01:11 PM
94boosted's Avatar
94boosted
Do these photos work for anyone? I think the links are dead.
Old Nov 9, 2014 | 04:40 AM
Kadorja's Avatar
Kadorja
Thread is from 06... most likely not active links anymore or the pics are removed.
Old Jan 11, 2015 | 08:17 PM
Z06Pops's Avatar
Z06Pops
Default tach signal wire 09 Z06
Originally Posted by KrazyC6
right now i have it set at 6300.....i connect all three wires to the harness under the engine compartment fuse box....open the box u'll see four bolts unscrew those then u can remove the fuse and relay box then u'll see four harness under it....all the wire can connect to the white color harness Pin A1(power B+ switched-yellow) Pin D1 (Ground-black) and Pin D8 (Tach Signal-White).....the ten feet cable on the light just makes to the fuse box
So - has anyone used this location (for the tach signal wire) in a 09 Z06?
