Header Install ??
Old Jan 10, 2006 | 10:32 PM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Default Header Install ??
Need to know. when installing headers..do i need to have new gaskets or are the c6 gasket reuseable...If i do need to buy a set where can i get a good set for kooks...
Old Jan 11, 2006 | 02:09 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Be on the safe side and buy new GM gaskets. Gaskets supplied with headers usually leak. $20 for new gaskets isn't much. Better safe than sorry.
Old Jan 11, 2006 | 03:00 PM
LS1LT1's Avatar
LS1LT1
GM OEM gaskets are the way to go and you can use the originals that came with the car but it's always a safe bet to start with brand new ones.
Old Jan 11, 2006 | 04:01 PM
davidfarmer's Avatar
davidfarmer
they can be reused many times.
Old Jan 11, 2006 | 07:14 PM
k-line's Avatar
k-line
My Kooks came with gaskets
Old Jan 11, 2006 | 07:23 PM
stinky's Avatar
stinky
As did mine, but those in the know say to use the original GM metal gaskets as they seal better, the others eventually will leak.
Old Jan 11, 2006 | 09:57 PM
BIGGGIE's Avatar
BIGGGIE
Thanks.. I Will Order a Set i though they would have to be a little bigger the opening for the Kooks..
To Header Install ??
