Just Joined Dbs Club
Old Jan 16, 2006 | 10:35 AM
vetdude's Avatar
vetdude
Default Just Joined Dbs Club
2006 C6. 254 miles on it. Car sat for two weeks due to lousy weather. Would not start this morning; battery dead.
Old Jan 16, 2006 | 10:50 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Plenty of posts here on it. Use search under DBS ,dead battery, etc.
Take to dealer, (who will not know anything about it) get it on writing in therir data base and KEEP a copy of the RO.
Old Jan 16, 2006 | 10:55 AM
nalto's Avatar
nalto
Is this the first 2006 with DBS?
Old Jan 16, 2006 | 11:43 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
2015 C3 of Year Finalist
No. Someone else had posted one about three weeks ago as I recall. I'm still not convinced that the problem hasn't been corrected on the 06. There are so many other possibilities like bad batteries and that stupid interior light switch that can cause it. It does not seem as prevalent as on the 05 MN6 cars.
Old Jan 16, 2006 | 12:08 PM
DJackman's Avatar
DJackman
Welcome to the club. I got my DBS a few days before the 1yr. aniversary.
Old Jan 16, 2006 | 12:32 PM
LS1LT1's Avatar
LS1LT1
Auto or manual...my 200 mile old auto has sat for 8-9 days straight so far?
Old Jan 16, 2006 | 12:57 PM
StanNH's Avatar
StanNH
We really need information about how your car is set up. There have been one or two posts reporting dead batteries in 2006 cars but both, I believe, were automatics. That's not what is typically considered DBS, since DBS has always been associated with the shift to reverse and/or steering column lock features on 2005 MN6 cars.
An occasional bad battery is what is currently thought to be the cause of these odd occurrences. Yours may or may not fall into that category. Again, please provide more information about the car and the circumstances so we can get a better idea of what actually happened here.
Old Jan 16, 2006 | 01:01 PM
AFVETTE's Avatar
AFVETTE
This sounds more like a weak battery than DBS. From my readings the real DBS can occure in about 24 hours of parking. Indicating some form of continous electrical draw. Your situation is more in keeping with a weak battery in a car that sat for 2 weeks, that could occur on any car.
I've followed this very close knowing I'd be buying a C6. I just ordered a 06 C6.
Good luck getting the dealer to do anything. I'm guessing once you get the car started and the battery charged it'll be fine.
Good luck
Tom
Old Jan 16, 2006 | 01:35 PM
CYA-Vett's Avatar
CYA-Vett
They don't know what the problem is/was, so they can't correct it. No matter what they say. It just sucks.
Old Jan 16, 2006 | 01:58 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Report your dead battery incident to GM @ 800 222-1020. We need to make them aware of this problem every time in occurs.
Old Jan 16, 2006 | 02:26 PM
VET4LES's Avatar
VET4LES
It could be just a bad battery. Let us know.
Old Jan 16, 2006 | 04:59 PM
tetsuo166's Avatar
tetsuo166
Any more info on this car? MN or Auto? Have you charged it or taken it to the dealer? Inquiring minds want to know if this really is DBS on a 2006 or not.
Old Jan 16, 2006 | 07:03 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
100%. How can they correct it if they don't know what causes it?
This case, just like the other reported '06 cases mentioned above by StanNH, , probably won't go down as classic Dead Battery Syndrome. Even those this battery is as dead as any of the others reported in the '05 cars.
Also, I thought that DBS occured 2 days or more after the car had been sitting.
Old Jan 16, 2006 | 07:39 PM
vetdude's Avatar
vetdude
OK guys. here's the info:
2006 Machine Silver/Ebony/Black Top Convertible
3LT
MN6
Z51
Nav
OnStar
Purchased 11/26/05. Odometer now reads 254 Miles. Had car on Battery Tender for a couple of weeks after purchase. Took it out two weeks ago, everything was fine. Did not put back on Battery Tender. Tried to start this morning, would not crank. Then, not enough power to even open doors. Lights would flash and got some strange noises from inside the car. Jumped battery with our other car. After a few minutes of charging, car fired up. Got several DIC messages (Service Active Handling; Service Vehicle Soon). Messages disappeared after turning car off, restarting several times. Now, all seems to be OK. Voltage readout 14.2 while driving. Car has NOT been back to the dealer...yet.
Old Jan 16, 2006 | 10:15 PM
ajfruscia's Avatar
ajfruscia
Not DBS, after 2 days car would be COMPLETELY dead...if it was DBS
Old Jan 17, 2006 | 08:34 AM
StanNH's Avatar
StanNH
It does sound like a bad battery cell, rather than classic DBS. You really should let the dealer check out the car and replace the battery if necessary.
Old Jan 17, 2006 | 08:59 AM
mikeyc6's Avatar
mikeyc6
Not DBS. If it were classic DBS, your car would act like an inert hunk of steel (and plastic/fiberglass) after 3 days: no lights, no nothing. The fact that there was any sign of life at all proves this isn't the classic DBS. Could be some "new" strain of DBS I guess.
Mike
To Just Joined Dbs Club
Old Jan 17, 2006 | 09:01 AM
VetVetter's Avatar
VetVetter
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
Probably having on the Battery Tender before just disguised the problem.
Old Jan 17, 2006 | 10:04 AM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Mike
I had what I thought was DBS a week ago. I had driven the car on Sunday for a couple of hours; then washed and Zaino'd it. The car sat on Monday and Tuesday. When I went to start it on Tuesday night, it would not start although the doors opened, the interior lights came on and the radio worked. When I pressed the Start button, it would emit a series of clicks and then nothing. Called AAA to jump it and then drove around for 45 minutes and then parked it again.
I had an appointment on Thursday to have the Nav software update done along with an oil change and included the dead battery to repair order. According the Corvette tech, he did not find any fault codes and the battery was putting out 700 CCA. Nothing has happened since then, but I am always a bit hesitant when I go to start it now.
Old Jan 17, 2006 | 03:09 PM
VET4LES's Avatar
VET4LES
