So I removed clutch spring and...
Old Jan 21, 2006 | 08:35 PM
kloudin's Avatar
kloudin
Default So I removed clutch spring and...
the petal now makes a click noise when it is depressed. The petal was quite as a mouse with the spring in place. Am I the only one that noticed this?
Old Jan 21, 2006 | 09:17 PM
achilds's Avatar
achilds
If it isn't broken don't fix it. I find the clutch to be just fine as it is. I also like the stock shifter. Maybe I am just abnormal?
Old Jan 21, 2006 | 09:19 PM
VET4LES's Avatar
VET4LES
Old Jan 21, 2006 | 09:29 PM
archtop's Avatar
archtop
Have fun putting it back in.
Old Jan 21, 2006 | 10:13 PM
GRX's Avatar
GRX
Why did you remove the spring anyway?
Old Jan 21, 2006 | 10:23 PM
kloudin's Avatar
kloudin
I took it out because I could never feel the clutch engage and read so many posts that if you remove it you can feel the clutch which you can. It feels so much better out than in. Anyway it now it make noise when first depressed just wondering if this is normal with it removed and would like responses from others that removed it as well.
Old Jan 22, 2006 | 01:10 AM
xs650's Avatar
xs650
How much stiffer would you guestimate it was?
Old Jan 22, 2006 | 02:09 AM
Atascadero_Kid's Avatar
Atascadero_Kid
Personally, I have much more fun with it when it is stiff....
Old Jan 22, 2006 | 01:28 PM
sallen619's Avatar
sallen619
My guess is 35% at least.
Old Jan 22, 2006 | 01:48 PM
xs650's Avatar
xs650
I guess that would bother the girlie men.
Old Jan 22, 2006 | 02:54 PM
EuroRod's Avatar
EuroRod
Yea, it is difficult to have fun with it, unless it's stiff. Stiffer the better I've always thought. Talkin' clutches, here. Right?
Old Jan 22, 2006 | 03:03 PM
kloudin's Avatar
kloudin
Well good news, the noise went away, guess I need to drive it more than out of the garage and then back in. The clutch is a bit stiffer and will agree, about 35% stiffer, the way it should be out of the factory. I love it! I can now feel the clutch engage and do no longer feel that the car is driving me.
Old Jan 23, 2006 | 12:24 AM
xs650's Avatar
xs650
How much trouble would it be to reinstall it if you get tired of no spring?
Old Jan 23, 2006 | 03:19 AM
cbrf4i1's Avatar
cbrf4i1
major pain, it took me 5 seconds to pop it out.....20 minutes or more and still couldn't put it back.
Old Jan 23, 2006 | 10:26 AM
Mr.Big's Avatar
Mr.Big
Took mine out several months back... Would do the same again...
Jeremy
Old Jan 23, 2006 | 04:24 PM
Vet's Avatar
Vet
I have a bone stock 2006 Z51 MN6... I think the clutch pedal / effort is perfect. I would never touch the spring. This is a comment coming from someone who previously owned a 455 Super Duty Trans Am with a high performance clutch. The C6 clutch feel is indeed lighter than the old beast, but certainly not "too light". Any typical foriegn car I've ever driven has had a lighter clutch.
I think my `06 C6 clutch feels excellent... I wouldn't want it any other way. I am wondering if anything was changed from 2005 to 2006? Maybe GM did some fine tuning to the clutches / springs etc for `06 ??? You guys have `05s, right? Is the pedal spring part number the same for `06 as in `05?
I thought I remember reading a post at the forum here that quoted a section from a C6 service manual or service bulletin, stating something to the effect that if the pedal spring is NOT in place, some level of clutch damage could occur. Anyone know about this? I can't seem to find it now. It may have been in a troubleshooting section... said something like "if the clutch is damaged, check for possible cause being a broken clutch pedal spring... etc...".. something to this effect.
I'm keeping my spring in place.
If anything, maybe a lighter spring could be swapped in... or maybe the existing spring could be modified to provide a little less pressure...? Probably better than no spring at all.
Old Jan 23, 2006 | 04:28 PM
blkc6z51's Avatar
blkc6z51
To So I removed clutch spring and...
Old Jan 24, 2006 | 07:57 AM
6 speed Sid's Avatar
6 speed Sid
If it starts making noise again try a little WD-40 on the moving parts.
Old Jan 24, 2006 | 08:25 AM
vetdude's Avatar
vetdude
Old Jan 24, 2006 | 11:19 AM
cerino2000's Avatar
cerino2000
I think someone had reported the clutch was more prone to the "sticking to the floor syndrome" when the spring was out.
The clutch did take some time to get used to since it is really hard to feel when it is going to engage but after a while you will get used to it and learn the car better.
