torque management
Old Jan 23, 2006 | 12:53 AM
sunsetZ51's Avatar
sunsetZ51
Default torque management
ok, im new to this forum and ive seen a lot of talk about "torque management" i just want to know what it is and how to eliminate it. thanks.
Old Jan 23, 2006 | 12:56 AM
06C6FVR's Avatar
06C6FVR
Buy an M6 Car!!!!
Just kidding, do a search and there are plenty of debate threads on the issue. Probably not a good idea to start another thread.
Daren
Old Jan 23, 2006 | 07:49 AM
davidfarmer's Avatar
davidfarmer
6-speeds have it too.
It is the PCM limiting power to protect the drivetrain. There are drivetrain specific limits (to protect componenets during shifts, etc), and there are rpm limits. These effectively limit the output of the engine, regardless of engine mods.
LS2edit easily tunes it out, or dials it back. I don't know if the other tuning software does so.
Old Jan 23, 2006 | 08:32 AM
jschindler's Avatar
jschindler
Yes, this subject gets beat to death. No doubt, some folks will give you a more serious answer than I will, because I don't believe that it exists on manual transmission cars. I believe it exists primarily on automatic cars to soften power output during shifts of the automatic transmission.
There are some who seem to think it's a conspiracy theory - GM gives the car 400 horsepower, then takes it away when you least expect it
David Farmer (who I generally respect, btw) says it limits horsepower available unless it is turned off. But if you go back on the forum a year ago, before anyone knew how to turn it off (assuming it really is there), there were cars being modded with 100 rwhp more than stock.
Old Jan 23, 2006 | 08:57 AM
sunsetZ51's Avatar
sunsetZ51
Well I work for GM so im gonna ask around and possibly give my buddy Ed Peper a call...ill get back to you hopefully with an official answer
Old Jan 23, 2006 | 11:46 AM
bunk22's Avatar
bunk22
I say wait and drive your car. If it feels fine and drives strong, wouldn't worry. If you have a car like mine that fell on its face during hard shifts with AH and TC off, maybe it needs some TLC from a tuner.
Old Jan 23, 2006 | 12:10 PM
zippin zee's Avatar
zippin zee
That would be awesome, I would love to hear some imput from some the people that actually work on the pcm developement.
Old Jan 23, 2006 | 02:31 PM
davidfarmer
jschindler, let me revise my post. I'm not saying it canlimit a car to 400hp at 5000rpm, but it can pull timing if you go above 400hp, cuttin perhaps 10-15hp from your car. If you're engine is capable of making 500HP, it might trim you back to 485 or so.
these are all hypothetical numbers/rpm. I don't know how aggressive the TM can be, but you can adjust the points at which it "kicks in".
btw, I appreciate the sort-of compliment
Old Jan 23, 2006 | 02:50 PM
rfopt's Avatar
rfopt
I don't think TM is limiting the car to 400HP. What it does, IMO, is limit the amount of power at certain ranges of the power curve only when certain situations exists that can stress the drivetrain more. Even then I believe it is just in small increments of time to smooth the application of shock the drivetrain takes. The peak torque and HP will still be there.
As an example someone does a real hard shift to second and they happen to be at 4500RPM after the shift the engine power may be cut back a little in a small increment of RPM and gradually bring back full power. Maybe there can be quite a few situations that trigger TM in an agressive 1/4 mile run that can increase 1/4 time by .1sec or so.
Assuming this is true, my opinion is why not just make the drivetrain strong enough instead of band aid fixes.
Old Jan 23, 2006 | 03:08 PM
jschindler's Avatar
jschindler
It was more than a "sort-of compliment". I do have a lot of respect for you
And by the way, I agree with you. If you research my posts going back over a year on TM, I have always said that I believe that if the computer sees something it is not supposed to see (meaning something not designed for the engine, like a different cam etc) that I believed it might step in and go into a self preservation mode.
Good response!
To torque management
