DEXRON VI Automatic Transmission Fluid ?
Old Jan 25, 2006 | 07:52 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Default DEXRON VI Automatic Transmission Fluid ?
I was reading a tech bulletin LINK on the new DEXRON VI Automatic Transmission Fluid stating all the improvments form DEXRONŽ-III. Have anyone does this change in the MN6?
Old Jan 25, 2006 | 04:33 PM
davidfarmer's Avatar
davidfarmer
http://www.imakenews.com/lng/e_artic....cfm?x=b11,0,w
Well, all of the improvements were specifically for an Automatic trans, so I'm not too worried about upgrading. Also, it appearanty won't be readily available for some time.
IMHO, it is basically a deal so that GM can get more money from Licensing. Every oil company that uses the Dexron name has to pay them an annual fee, which I'm sure only get's more expensive with new products.
Old Jan 25, 2006 | 06:00 PM
calemasters's Avatar
calemasters
For 2006, only the automatic uses DEXRON VI ATF.
The 2006 MN6 manual 6-speed uses DEXRONŽ-III Automatic Transmission Fluid, with the Approved H-Specification, just as in 2005.
Old Jan 28, 2006 | 08:08 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Originally Posted by calemasters
The 2006 MN6 manual 6-speed uses DEXRONŽ-III Automatic Transmission Fluid, . . . just as in 2005.
And that is a GOOD THING. Dexron VI is one grade thinner viscosity than Dexron III. And ATF is on the thin side for manual transmissions anyway . . .
To DEXRON VI Automatic Transmission Fluid ?
