z06 panels on a z51
Old 01-26-2006, 03:36 PM
c6 corvette Z51
c6 corvette Z51's Avatar
Default z06 panels on a z51
will all the parts fit? i bought the front , the 2 front carbon panels and the 2 rear panels. will i have a problem putting them on? one person said that you have to do a little trimming in order to make them fit. (trim what?)
Old 01-26-2006, 03:44 PM
blown34
blown34's Avatar
Default Panels?
Are you talking about fenders or the Z06 mud guards?
Old 01-26-2006, 03:49 PM
cerino2000
cerino2000's Avatar
I think the trimming was talking about putting the Z06 outer rubber guards (can't remember what they are really called) onto the regular C6 rear quarters. You should be fine. In fact, be sure to post your results in getting it all on there.
Old 01-26-2006, 04:15 PM
Jeffvette
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
You have to buy the Z06 nose if you are going to use the front fenders.
Everything bolts up.
Old 01-26-2006, 04:46 PM
cerino2000
cerino2000's Avatar
Very cool! What was the total investment?
Old 01-26-2006, 04:48 PM
Jeffvette
Jeffvette's Avatar
Front fender 1,800 each, rear fenders 280 each, front nose 400, misc parts about 500 and paint.
Old 01-26-2006, 05:24 PM
cerino2000
cerino2000's Avatar
AHHHHH! Man that CF is expensive!!! Really does look cool too. You may be the first to do it.
Old 01-26-2006, 06:10 PM
Jeffvette
Jeffvette's Avatar
It wasn't me, these are shots from MTI down in Houston. There is a Monterey Red vert getting the same treatment. Both cars are getting 427's as well.
I've been thinking about doing it to mine, but can't really justify it.
Old 01-26-2006, 08:40 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Looks sort of odd with the Z51 brakes.
Old 01-26-2006, 09:48 PM
excessive81
excessive81's Avatar
you will need new wheel well liners and brake duct work. i just finished mine and other then that it will bolt on no problem. no trim needed at all.
Old 01-26-2006, 09:50 PM
excessive81
just did mine and ithe rear bolts on fine no trimming needed.
Old 01-26-2006, 10:18 PM
Brabus2
Brabus2's Avatar
I'm in the SFV area too, would luv to see your finish results.
Old 01-26-2006, 11:31 PM
midnite902
midnite902's Avatar
I like the Carvaggio wide fenders without the scoops better. They retain the smooth lines of the C6. Trying to decide between wide fenders or a mini-tub.
Old 01-27-2006, 10:21 AM
OtherTime
OtherTime's Avatar
Its a convertable, even more odd. oh and whats up with the hood sticking up. Is it not closed all the way??
Old 01-27-2006, 11:19 AM
Jeffvette
Jeffvette's Avatar
It's awaiting a engine transplant, and the brakes are not available.
Old 01-27-2006, 01:32 PM
Dvlray6
Dvlray6's Avatar
St. Jude Donor '07-'08-'09
Can anyone who has done this post the GM part numbers needed?
Thanks in advance!
Old 01-27-2006, 03:35 PM
railgun
Support Corvetteforum!
railgun's Avatar
How much for the aluminum frame?
To z06 panels on a z51
Old 01-27-2006, 08:30 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Your car looks familiar, was it at LAPD awhile back?
Old 01-27-2006, 09:51 PM
Brabus2
Brabus2's Avatar
Yes, Shawn & the LAPD crew did my Borla exhaust, Kooks header & Wilwood BBK install a few months ago.
Old 01-28-2006, 01:09 AM
tbyrne
tbyrne's Avatar
Location: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
I think I'm going to be going this route with my convertible also. Also add the Z06 brakes and GM Z06 wheels to the list. The wheels are the main reason for doing all of this (well... at least they are a good excuse ). Someone mentioned that the rear bumper has a different part number for the Z06 but everything looks to be the same. I'm currently looking for a good (I mean good) body shop to take care of the paint. Overspray isn't an option and I don't want anything to be a different color in a year or two. This is the main reason why I usually don't do any exterior mods like this.
Quick Reply: z06 panels on a z51
