Priority Start Mounting
Old Jan 30, 2006 | 11:44 PM
78PC's Avatar
78PC
Default Priority Start Mounting
What side of the battery are the Priority Start guys mounting the unit? Inboard toward the engine and exhaust manifold, or on the out board side toward the fender? Has there been any reported problems due to heat if mounted on the engine side of the battery?
Old Jan 31, 2006 | 05:32 AM
prs62's Avatar
prs62
St. Jude Donor '05-'07
I mounted it on the inboard side toward the engine. So far (about 2 months) no problems with engine heat effecting the unit.
Old Jan 31, 2006 | 08:11 AM
blittle's Avatar
blittle
The only place I could seem to mount it so that everything reached correctly was on the inboard side........no problems with heat. However, I am concerned that the "rubberband" will be affected by the heat and eventually break.
Old Jan 31, 2006 | 09:33 AM
Steve Germany's Avatar
Steve Germany
Old Jan 31, 2006 | 09:35 AM
05_C6Z51's Avatar
05_C6Z51
What stores carry the Priority Start?
Old Jan 31, 2006 | 09:54 AM
dbradley's Avatar
dbradley
Yep, the rubber band looks kinda lame. I'm looking for the mother of all ZIP ties......
Old Jan 31, 2006 | 11:29 AM
blittle's Avatar
blittle
Yeah.....that band is definitely going to "dry out" and come apart
Old Jan 31, 2006 | 12:20 PM
mikeyc6's Avatar
mikeyc6
You said it! That rubber band is the first thing I noticed and to be honest, the thing wasn't strong enough to hold the PS tight to the battery anyway with all of those heavy gauge cables attached. I zip tied mine in addition to the rubber band. Just get some big zip ties and attach two or three together (however many you need) to get around the battery.
P.S. Mine is on the inboard (engine) side of the battery. It's very difficult to place it anywhere but there. No problems yet and it has been maybe 6-9 months.
Mike
Old Jan 31, 2006 | 12:38 PM
blittle's Avatar
blittle
I think what I might try is some commercial grade velcro on the back of the PS and see if it will help hold it to the battery.................
Old Jan 31, 2006 | 01:23 PM
VET4LES's Avatar
VET4LES
Has anyone had it cut off the power yet? And when that happen's do you need to use the key to get in and how do you reset it?
Old Jan 31, 2006 | 01:36 PM
mikeyc6's Avatar
mikeyc6
I'm not sure even industrial velcro would hold it in place tight enough for my taste (too much wobble). Also, the adhesive on the back of the velcro probably wouldn't hold long in that heat.
Yes. I left the car unattended for about a month once and it eventually cut power after about 30 days. You use the key in the trunk, pop the door, and press in the cigarette lighter: instant power.
Mike
Old Jan 31, 2006 | 05:03 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
I purchased a Deltran Battery Tender for the winter months, but intend to get a Priority Start unit in the spring. Can these be hooked up together? Also, where did you get the Priority Start unit? I've seen the "Battery Drain Protector" in Griot's Garage ($70), and I assume that it is the same as the Priority Start. Is one better than the other?
Old Jan 31, 2006 | 05:07 PM
VET4LES's Avatar
VET4LES
Mike
Old Jan 31, 2006 | 05:47 PM
blittle's Avatar
blittle
I did a search on Yahoo shopping and found a vendor with a good price.......however, did it so long ago I don't remember the name But I know it was something like $50.00.
Old Jan 31, 2006 | 06:19 PM
78PC's Avatar
78PC
Default Thanks
Thanks for the info. I mounted the unit on the inside toward the engine. The rubber band supplied with the Priority Start is sad. I emailed Priority Start directly and they are sending me an additional rubber band. I will double up on the rubber bands and hopefully it will assist in holding the unit more snugly. The unit sags way too much using the single rubber band. I also thought about using commercial grade velcro, but the adhesive would probably not survive the heat.
Old Jan 31, 2006 | 07:43 PM
Devils Elbow's Avatar
Devils Elbow
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Yes, 10 times so far
I use the key to get the trunk open, pull the door release cable and press in the cigarette lighter for about 2 seconds to get PriorityStart to re-connect - then I'm good to go until the next time. Sure is nice to have a "keyless" entry system
Old Feb 1, 2006 | 06:29 AM
blittle's Avatar
blittle
I have an EZpass module mounted with commercial grade velcro in the engine compartment on the fender wall. So far, it hasn't moved so I think I'll try it with the PS unit in addition to the rubber band. Can't hurt.............
To Priority Start Mounting
Old Feb 1, 2006 | 03:39 PM
78PC's Avatar
78PC
Default York, Pa
I passed through York, PA when out there from CA., enroute to Gettysburg. Was that your vette photos on CF taken at the battlefields in Gettysburg? If so, nice photos.
Old Feb 2, 2006 | 07:38 AM
blittle's Avatar
blittle
Not sure which photos you are speaking of .................but our club did do a show last summer in Gettysburg, but I was out of town and did not make that one. Thanks for the comlpiments
Old Feb 9, 2006 | 09:03 PM
dashotgun's Avatar
dashotgun
if anyone needs a priority start I recomend www.batterymart.com
I also would have wanted the front of the battery but I don't think the positive cable stretches that far.
