I'll probably get flamed for it, so flame suit on.
I've put them on 3 different cars now and have never been able to feel a difference. Maybe its just my club feet, but to me, its a waste, unless you are replacing the stock ones due to age.
I put some on an 8 year old C4 and noticed a small difference. Maybe because the lines were older, maybe because I changed the fluid and bled the brakes at the same time, or being realistic, maybe because I wanted to notice a difference. I've put them on a motorcycle where the entire brake line was reinforced rubber and that did make a diference.
I would need to see a double blind study where stock systems were bled with fresh fluid and compared with steel braided lines by drivers that didn't know which they were driving. Then maybe I could get on the steel line bandwagon for newish cars.
Check for past post on this subject. I remember this question awhile back and the answer was that it is not a good idea. I don't remember why so it would be worth checking.
I just put some on today. Pedal seems a "firmer" than before. I need more time behind the wheel for a more acurate response. I do know the one's I got didn't fit and my installer had to "adjust" the mounting bracket on the car to get them in.
I thought so
Ill save my $120 and not get them.
I had them once on a motorcycle and it made a difference.
But have heard no reason to do on the car unless tracking !
I agree. I had StopTech stainless steel brake lines put on a previous car (Mercedes C32-AMG) and I could not tell the difference between the OE lines and the ss lines. My friend also did that mod at the same time on his E46 M3 and he also reported no difference.
We drove with the ss lines both on the street and also on a road course track. (To be fair this was some time ago, towards the early part of both my friends and my track experiences.)
Maybe on a Corvette the experience would be different, but it didn't seem to make a difference on a C32 or a M3.
For heavy duty use, as on the track, when the rotors are getting above hot several 100 degs F and the brake fluid is getting hot the steel lines are said to maintain a firm non elastic pressure to the brake pistons. Personally I believe it and my garage will have SS lines ( along with tons of other mods) waiting for my new C6 Z51 to arrive.
Heat causes the brake lines to expand losing some braking ability. Fluid heats up (rubber retains heat vs ss for starters) and breaks down, bubbles, reducing pressure).
You proly wouldn't notice on the street because the fluid tends to stay at cooler tempatures due to less braking frequency. The track is a far different story and worth it for a "good" SS line in my opinion.
of the cars I have put them on , 2 have had extensive track usage, and still no difference to me. to each his own though, like I said, maybe I just can't discern the difference.
