Codes after Header install - Kooks vs LGs
Old Feb 1, 2006 | 06:38 PM
Cookee's Avatar
Cookee
Default Codes after Header install - Kooks vs LGs
How is the long tube LG vs. the shorter tube Kooks in throwing codes?
The difference of sensor location on the LG and Kooks is quite a bit.
Without editing how many of you are getting codes with the new LGs?
How many with the Kooks?
Old Feb 1, 2006 | 07:06 PM
midnite902's Avatar
midnite902
I was getting a "cat heat sensor warning" CEL but it was tracked down to a damaged O2 sensor. No other codes in 6 months on my C6.
Old Feb 1, 2006 | 07:30 PM
m3corvette's Avatar
m3corvette
Kooks on my C6 for a year and never any codes just HP.
Old Feb 1, 2006 | 07:50 PM
Cookee's Avatar
Cookee
midnight are you running LGs?
Old Feb 1, 2006 | 09:26 PM
CYA-Vett's Avatar
CYA-Vett
Its all in the tune...Good tune=No Codes
Old Feb 2, 2006 | 07:33 PM
radstoy's Avatar
radstoy
No codes here with Kooks LTH, hi flo cats and Corsa exhaust.
Old Feb 3, 2006 | 12:33 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Ditto. Even w/o a tune. Tune came later.
Old Feb 3, 2006 | 03:19 PM
Devils Elbow's Avatar
Devils Elbow
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
LG headers w/cats, Borla, no tune - no codes
Old Feb 3, 2006 | 03:37 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
LG's since middle dec, no codes.
Old Feb 3, 2006 | 04:24 PM
bunk22's Avatar
bunk22
I've got the Looks with cats and have had no codes.
Old Feb 4, 2006 | 06:53 AM
SpinMonster's Avatar
SpinMonster
I had a lean condition code until it was tuned...Kooks. It is not just if you have headers but what your other mods are that totals a different A/F ratio.
Old Feb 4, 2006 | 07:10 PM
Cookee's Avatar
Cookee
Thanks guys, It appears that there is no difference between the Kooks and LGs for throwing codes.
Old Feb 4, 2006 | 09:14 PM
silvre c6's Avatar
silvre c6
Halltech SSm;Kooks L.T. Hi-Flow cats;X-pipe;and callaway Double D Exhaust and no codes yet (05 C6 Z51 6spd) no tune yet,but seat of my pants FAST!
Old Feb 5, 2006 | 12:06 AM
SpinMonster
No headers throw codes. If your car needs tuning due to the combo of mods you run then you get a check engine light. Different mods cause changes in fueling and the car can only compensate so far to maintain stoic. ALL CARS run leaner at closed loop with headers which causes more fuel to be dumped in on WOT. Closed loop will remain at 14.7:1 to a point then it will lean out beyond that causing the check engine light. It isn't a header malfunction or poor design.
To Codes after Header install - Kooks vs LGs
